AMP/subs problem....
Old 11-05-2001 | 04:40 PM
Crazy Bimmer's Avatar
OK my subs are being weird now, actually more like my amp is. My amp cuts out at LOW volume... isnt that weird?!?! Like it shuts off completey! I have to have the voulme all the way up for it start. I tried to adjust the bass control on the EQ but its still doing it. Only at low volumes.. what can be the problem? You guys think its the amp, or the wiring? If it matters, its the Directed 1100d amp.
Old 11-05-2001 | 05:40 PM
SumkidwithaCL's Avatar
Turn Signals are good!
It sounds weird, but make sure your remote turn on wire isnt connected to a speaker wire, I've seen that done before, and the amp would only be on when there was a peak in the music.
Old 11-05-2001 | 06:08 PM
SilverKnight's Avatar
Retired. Not available.
told ya!!! your amp sucks
Check the remote wire. I hope your installer screwed up, otherwise, I get to laugh at your amp again
Old 11-05-2001 | 09:33 PM
hahaha DICK!! I dont think it can be the remote since It just started to do it. It worked fine before.
Old 11-07-2001 | 12:51 PM
chikai's Avatar
trying to get a lil V-I
My old Kenwood Monoamp did this too.
I would have to crank the sucka to get the bass going. But in the end I still couldn't figure out what was wrong with it. (I traded the car in for the CL-S like a month after it started doing this)
Here are a few things you can check:
- Make sure you have a good solid ground. Take a steel wool to the contact area to make sure it's metal to metal.
- Check the remote to make sure it's connect correctly.
- Buy a 1 farad cap...i'm not familiar with Directed's amps, but it could be pulling so much power that your battery can't handle it.
Old 11-09-2001 | 10:25 PM
spiroh's Avatar
Did you call Directed?
ajbrickyard
1G RL (1996-2004)
06-12-2007 04:04 PM
SSM6MTNAVI
01-31-2007 08:36 PM
r3mix3r
12-17-2004 12:47 PM
Idyfohu
02-24-2004 07:09 PM
Gilgamesh
03-07-2003 05:59 PM
Quick Reply: AMP/subs problem....
