Amp and Speakers install (pics..)
Old Mar 23, 2004 | 12:09 PM
VTEC11's Avatar
here's some pics from my install this past weekend. still have work to do in putting some parts of the car back together and installing the rear speakers..
See if this works..
3/4" Speaker Spacer...
Old Mar 23, 2004 | 12:11 PM
VTEC11's Avatar
Another
Old Mar 23, 2004 | 12:14 PM
VTEC11's Avatar
Speaker
Old Mar 23, 2004 | 12:16 PM
VTEC11's Avatar
VTEC11's Avatar
Old Mar 23, 2004 | 12:17 PM
VTEC11's Avatar
DEI Line Output Converters
Old Mar 23, 2004 | 12:19 PM
VTEC11's Avatar
Hooking up the amp. Rockford punch 600a4 as temp soution..
Old Mar 23, 2004 | 03:12 PM
AcuraX2's Avatar
Looking good so far. Keep it up.
Old Mar 23, 2004 | 03:13 PM
NSXNEXT's Avatar
Looks great Ritesh. How do they sound?
Old Mar 24, 2004 | 03:37 AM
wth718's Avatar
What model CDT's are those? I was looking into the CDT classics but wasn't sure if they would fit.
Old Mar 24, 2004 | 04:21 PM
NaturalTLS's Avatar
nice!
nice one! I had the same speakers but did not have the tools to make the spacers. did you have to cut into the door at all? Would you make me some spacers for some $? I really wanted to use the cdt components but was forced to sell them
How do they sound?
Old Mar 25, 2004 | 02:09 PM
TLBaller's Avatar
after you put on the spacers, are you able to put back the door panel? if so, im guessing they dont stick out TOO much?
Old Mar 25, 2004 | 03:58 PM
VTEC11's Avatar
thanks for the replies guys..
TLBaller,
The spacer is 3/4" which is the same size as the factory spacer, so putting the door panel on is not a problem at all.
NautralTLS and wth718,
They are the classic series CDT's: cl61's, cl-6x's for the back (although havn't put those in yet). I wasn't sure myself if they would fit because on the CDTaudio website, the woofers are rated as being 2 13/16" deep, while all there other woofers were rated at 2 3/4". I believe they actually are 2 3/4" but there is a rubber cover around the maget that you can remove to reduce the top mount depth just slightly. I actually measured the speaker as 2 5/8" (2.625") without the rubber cover. And this just cleared the window with a 3/4" spacer. ALso, as you can see from the pics, I didn't have cut any metal off the door.
I'll have some pics of the actual speakers that i'll post tonight after i get home..
Neil,
they sound fantastic. The amp is pushing around 75-85watts RMS to each speaker and they really move ALOT of air. They don't disort at all even at full volume, crystal clear. I'm sure they can handle much more power. And i havn't even put on any dynamat or anything as of yet. Also the tweeters are still just sitting on the floor, not yet mounted.
My GF couldn't understand why i spent so much time doing this "stuff" to my car, but even she agreeded these kick butt after she heard em..
Old Mar 25, 2004 | 06:49 PM
NaturalTLS's Avatar
When are u adding subs?
Old Mar 25, 2004 | 09:34 PM
wth718's Avatar
Thanks for the info!
Old Apr 8, 2004 | 03:01 PM
VTEC11's Avatar
How do they sound?
NatualTLS,
Sorry I didn't read this post too closely before. Yeah I can make the spacers for you out of wood if you like. It will work fine especially if you use the CDT's (no door cutting involved). You just have to give me a few weeks I've been really busy with stuff recently.
Just PM me.
thanks..
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
