which amp should i use?
Old Jun 4, 2003 | 01:40 PM
brianlin87's Avatar
ASM I.S. Design FTW.
i have 1 12JLW3 and i was wondering which amp would be best to power this sub... im inclined towards using a JL sub to keep it all consistent, but am not sure which one would fit best... any suggestions? thanks
Old Jun 4, 2003 | 11:18 PM
kimxhiep1017's Avatar
you can get any amps that put out 300w RMS, then you will be fine.
Old Jun 5, 2003 | 12:24 AM
JaySyn77's Avatar
But make sure the amp gives out the power at the right ohm load. I'm not sure if you have the Dual 2, 4 or 6 ohm sub.
Wired in (P)arallel or (S)eries
Dual 2 250-300watts at either 1ohm(p) or 4 ohm(s)
Dual 4 250-300watts at either 2ohm(p) or 8ohm(s)
Dual 6 250-300watts at either 3ohm(p) or 12ohm(s)
That I know of..you wont find specs for an amp at 3ohm or 12ohm. Most amp specs are at 1,2,4 & 8ohms
Old Jun 13, 2003 | 12:18 PM
ebednarz's Avatar
If you can get your hands on a JBL 300.1 mono sub amp, that'll prob. be your "best bang for your buck." Great amp. I saw several on ebay. I'm running the JBL 600.1 for my 2-12's. Amp kicks arse.
Old Jun 13, 2003 | 12:31 PM
Scooter's Avatar
'Cooter
how bout this???
1600W max power
500W x 1 into 4 ohm, 20Hz - 300Hz, @ 0.2% THD
900W x 1 into 2 ohm, 20Hz - 300Hz, @ 0.6 THD
Class D
Variable 50 - 300Hz 12dB/oct Low Pass Filter
40Hz EQ Boost
RCA and Speaker Level Inputs
Speaker Impedance -- 2 - 8 ohm mono
Frequency Response -- 5 - 300Hz
Input level range -- 0.3 - 6V (RCA), 1.2 - 12V (High level)
Power Supply Voltage range -- 10.5 - 16V
Current drain (at rated output 2 ohm) -- 90 A
Old Jun 13, 2003 | 04:58 PM
meeh416's Avatar
JL 250/1 is the right amp for that sub 250 watts rms @ 2 or 4 ohm. or ppi pcx 1250, 250 watts @ 4 ohm and 500 @ 2ohm. also both of those two amps are around $300.
Old Jun 14, 2003 | 02:51 PM
shawhite_RENAMED's Avatar
jl audio all day....
Old Jun 14, 2003 | 05:13 PM
brianlin87's Avatar
thanks for all the feedback... i think i'll follow meeh416's advice and get a 250/1 amp
Old Jun 15, 2003 | 07:53 AM
good choice... i have the 300/4 and the 500/1 and could not be happier....
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
