amp power wire to battery
Old Apr 22, 2007 | 10:39 PM
ll1l2l1l2lll's Avatar
w202 on carlssons
where do i connect the power for amp to the battery. i'm installing my sub soon and i want to do this. i don't want to drill a hole in my firewall. i know there is an unused hole somewhere.. btw, i have a 2001 CL-P.. does anyone have a pic of their engine bay that shows where their wires are running from? greatly appreciated it someone did that for me.
Old Apr 23, 2007 | 12:15 AM
daicacharco's Avatar
fire wall ... ? you just cut a little hole on the rubber peice and stick your power wire through there.
you connect the power wire to the postive terminal of the battery
Old Apr 23, 2007 | 12:17 AM
dreem1er's Avatar
deal with it
well i ran my wire through the fender, then through the gourmet thats on the driver's side door, the rest is the same under the sills and the back seat into the trunk.....works fine.....
Old Apr 23, 2007 | 11:18 AM
KaMLuNg's Avatar
i'm sorry, no offense but if you should be asking this question, i don't know if you should be completing this install...
but to answer your question... positive terminal... and there is a rubber plug towards the center of the firewall... u can just push it out with a screwdriver, then snake your power line through there and it will come out under the driver side dash area...
Old Apr 23, 2007 | 11:53 PM
w202 on carlssons
sorry, i wasn't refering to where i conenct it.. i ment from where do i run it -___-"
Old Apr 24, 2007 | 07:54 AM
KaMLuNg's Avatar
oh okay.. then that is better...
Old Apr 25, 2007 | 01:31 AM
w202 on carlssons
details please on where you cut the hole and run the wire? i know you connect it to the positive i just can't figure out which hole you run it through and where that leads. i know my integra, i just unplugged a grommet and it came through fine.. but with my CL, i'm not sure. anyone have pics? i'd greatly appreciate it.
Old May 19, 2007 | 08:52 PM
Landocommando12's Avatar
I would also like to see if anyone has pics of where this is exactly at before I start my install.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
Phambam12
Sep 6, 2015 06:57 PM
