amp power
Old Dec 5, 2004 | 02:03 PM
x911gt2's Avatar
amp power
I have a question regarding amplifier power....I have a 12" kappa perfect sub i need to power...its rated at 350w RMS....so i was looking into a few amps for it...
I came across the alpine mrd-m501 which is a mono amp rated at 250wx1 @ 14.4...it would run me around $250 new. Then I happened to come across the alpine mrd-t420 which is a 2 channel amp....i noticed that this amp can be bridged to give 340w RMS x 1 @ 14.4...the amp is also about 60 bucks cheaper...
Is there any difference in power when the amp is bridged? are there any benefits to getting a mono amp over a multi-channel amp that can be bridged?
Old Dec 6, 2004 | 12:09 AM
elduderino's Avatar
VP Electricity
While there are some theoretical reasons to prefer a mono over a bridged, the main reasons are practical: A mono channel is usually 2 ohm stable, and a bridged amp is usually 4 ohm stable (2 ohms for the left and 2 ohms for the right, bridged together, makes 4 ohms, is the simple way to remember it).
So if you have a single 4 ohm voice coil sub, a bridged amp will put out max power, but a mono will not. If you have a single 2 ohm VC or a pair of 4 ohm VCs paralleled to 2 ohms, you will get max power out of a mono amp, but you will shut down most bridged amps.
Old Dec 6, 2004 | 12:41 AM
x911gt2's Avatar
Gotcha, well my sub runs at 4 ohms...so ill go with the 2-channel amp...
funny, how did i know you were gonna be the only person to answer me...lol
thanks eld
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
