amp placement
Old May 12, 2008 | 02:56 PM
09_Type-S's Avatar
DO WORK!
amp placement
so i took out my spare tire and placed my amp in that spot, should i try to add means of cooling or do you guys think it will b ok there underneath the carpet cover? what could i do to add cooling down there? thanks
Old May 12, 2008 | 06:58 PM
feuss2's Avatar
10001110101
consider relocating...
Old May 12, 2008 | 11:22 PM
Soccer_playa1579's Avatar
yeaa... relocate bro... mine gets really hot just sitting in the trunk it self... i havent even mounted it yet :/l... prolly should do that because it jus has freedom to move aroundin the back...
Old May 13, 2008 | 08:52 AM
09_Type-S's Avatar
DO WORK!
dam i was thinkin if i put 2-3 cpu cooling fans and cut some ports in the trunk floor cover.
Old May 13, 2008 | 01:45 PM
Reach's Avatar
I'd relocate just to get your spare back! You'll only ever get 1 flat without a spare, after that you'll carry one.
Old May 13, 2008 | 01:55 PM
DiaBando's Avatar
gistered User
Absolutely!! What amp are u running?
Old May 13, 2008 | 02:05 PM
DiaBando's Avatar
gistered User
Ah, I see now. JL should run pretty cool. even warm-they are built like a BSH. I keep my audisons mounted on 1/4 fibre board shaped to the bottom of the trunk. I'm more concerned about movement; up, down sideways than heat.
Old May 13, 2008 | 04:06 PM
09_Type-S's Avatar
DO WORK!
yea thats how i have mine set up except on a peice of 3/4 inch board. i felt it after a 2 hr road trip, it was pretty warm.
Old May 13, 2008 | 08:20 PM
DiaBando's Avatar
gistered User
So, your Sub is run off the JL, too? That might be why it runs pretty warm. Dunno. I always went with a separate amp for a sub. JL sub is what 2ohm?
Old May 13, 2008 | 08:41 PM
09_Type-S's Avatar
DO WORK!
yea its all running off one amp fronts rears and brigded for the sub.
Old May 13, 2008 | 10:19 PM
DiaBando's Avatar
gistered User
My gear is spread out all over the FB (see my signature)-then covered with a shaped FB 'lid' in 2 sections over that, pretty stealth-except for the sub, and the amps get warm to the touch-but nothing disconcerning even in summer. What power cable size are you running? Again, even warm, good amps are designed to take the confinement. Does JL offer a cooling system?
Old May 14, 2008 | 08:44 AM
09_Type-S's Avatar
DO WORK!
im running 4 guage wires, for power and ground. the JL amp does not have a cooling system. but i read in the manual that they say its ok to mount underneath a seat if there is atleast 1inch of clearance above the top of the amp, so i dont think it should be an issue if i have it in the spare tire compartment.
Old May 14, 2008 | 03:27 PM
DiaBando's Avatar
gistered User
Well, keep the spare. I wouldn't travel a mile, let alone 2 hrs. without one. And your amp will shutdown before serious over-heating, and then you will know about the placement. Just don't 'drape' anything over it.
Old May 14, 2008 | 03:48 PM
09_Type-S's Avatar
DO WORK!
alrite, i think im just gona try to mount it on the back of the seats. thanks
Old May 15, 2008 | 01:19 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
^^^ Was just going to recommend mounting to the back of the seat, much better for the heat to dissipate
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
