AMP installation tips
Old Apr 20, 2004 | 09:55 AM
Dan Martin's Avatar
Photography Nerd
Post AMP installation tips
Does anyone have any tips on hooking up my amp? If I get out of here in good time tonight I might hook it up. I've installed a couple amps in the past but there's always some tricks that you figure out as you are doing the install.
Where did you guys run the power wire through the cabin? I'm thinking about running it along the drivers side door under the plastic trim along the floor.
Also, what grommet did you poke the wire through the firewall?
Anyone take pictures during the install?
Old Apr 20, 2004 | 11:01 AM
callmetsx's Avatar
Spooooooon !
Re: AMP installation tips
These are good questions. It took me a while to find a good place to put the power cord through, but there is a good rubber gasket on the passenger side about knee-high that you can push the cord through. Its the biggest one in view, so its easy to find, and the cord will pop through the firewall just where the rug ends in the footwell (towards the center console more than the speaker). Just keep pushing the cord through...eventually it will pop out.
I usually run wires under the plastic trim, and this install was no different, plenty of room in there, but its nice and tight as the car is new so it takes some effort.
Old Apr 20, 2004 | 11:05 AM
Dan Martin's Avatar
Photography Nerd
Cool that's the kind of info I'm looking for. Thanks!
Old Apr 20, 2004 | 03:29 PM
ortiz's Avatar
Don't listen to me.
I have pics that might help on this thread.
I got my stereo supersized today!
Old Apr 20, 2004 | 03:41 PM
callmetsx's Avatar
Spooooooon !
Nice install Ortiz - you went through a different gasket than the one I did if you used one on the drivers side, but it looks like it worked fine for you.
I couldn't reach any other but the one on the passenger side. What color wire did you connect as the remote turn on lead ?
I conencted my amp to the Yellow/red wire and it turns on with the stock radio.
Old Apr 21, 2004 | 12:21 AM
ortiz's Avatar
Don't listen to me.
Same here.
Old Apr 22, 2004 | 12:30 PM
jiggaman's Avatar
I spend 2 much time here
dan are you planning on replacing the stock amp? or just adding one for subwoofers?
Old Apr 22, 2004 | 12:45 PM
Dan Martin's Avatar
Photography Nerd
I have a 12" sub and box with a Pioneer mono amp left over from my Golf. It's been sitting around for a year and none of my friends wanted it so I'm going to hook it back up. I was actually pretty happy with the stock system but I figured I've already paid for it so I might as well use it. Nothing fancy really. If I feel inspired I might machine some adapters to use 8" woofers where the 6x9's go and get rid of the 12".
Old Apr 22, 2004 | 01:53 PM
ortiz's Avatar
Don't listen to me.
If you do this let me know. I may be intrested in this also.
Old Apr 22, 2004 | 02:02 PM
Dan Martin's Avatar
Photography Nerd
Will do. I'm going to take the measurements for everything when I install the amp. If I'm going to make one set I might as well make two....
Old Apr 22, 2004 | 02:22 PM
ortiz's Avatar
Don't listen to me.
Sweet!
Old Apr 22, 2004 | 05:15 PM
slo007's Avatar
Master in Science
Good idea. I wonder if it's feasible.
Old Apr 23, 2004 | 10:07 PM
Dan Martin's Avatar
Photography Nerd
Just FYI , the gromet on that ortiz used to put the power through the firewall is being occupied by the clutch pedal if you have a 6MT. I'm going to look for the gromet that callmetsx used tomorrow...
Old Apr 24, 2004 | 12:24 AM
ortiz's Avatar
Don't listen to me.
You can try going through the wireing harness just above and to the left of that gromet.
Old Apr 24, 2004 | 10:27 AM
Dan Martin's Avatar
Photography Nerd
I'm about to head out there and try again. If I can't get it through that wireing harness I'm just going to drill a hole and use my own gromet.
Does anyone see any issues with using the cigarette lighter in the center console under as a place to connect the remote power switch? I want to leave the head unit as untouched as possible in case I have trouble with it down the road (lights going out).
Old Apr 24, 2004 | 11:47 PM
ortiz's Avatar
Don't listen to me.
I don't think you will have any problems with that.
Old Apr 24, 2004 | 11:55 PM
Dan Martin's Avatar
Photography Nerd
Well 6 hours later I got everything working. Major pain in the ass job. I still have to tune in everything but the end is in sight. Thanks for the help guys!
Old Apr 25, 2004 | 12:09 AM
ortiz's Avatar
Don't listen to me.
How does it look? (pics please) How does it sound? ( just a breakdown of your opinion)
Old Apr 25, 2004 | 12:16 AM
Dan Martin's Avatar
Photography Nerd
You don't want to see pics because it's a pretty ghetto rig. The amp is about 4 yrs old and the sub is about 2. I still need to mess around with my amp's crossover and bass boost because it seems to be really peaky. What is the crossover point of the 6x9's? Also does anyone know if the door speakers are full range?
Old Apr 25, 2004 | 12:17 AM
Dan Martin's Avatar
Photography Nerd
I did do one cool thing when I hooked it up... I put a switch on the remote power switch line so I can turn the amp on and off manually.
youngTL
5G TLX Performance Parts & Modifications
55
May 23, 2020 07:39 AM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
IIDXholic
Oct 8, 2015 07:53 AM
Pegon95
Sep 15, 2015 01:54 PM
Nicho863
Sep 2, 2015 08:12 AM
