Amp install on 3.2 Cls(2001)
Old Aug 9, 2007 | 10:34 PM
Min5ki's Avatar
Hey new here and been trying to install an aftermarket amp and just wondering what did u guys use as the remote wire did uou connect it from the back of the headunit or the stock amp.
Also i am going to keep my stock headunit and was wondering how did you go about installing a sub i have already bought the converter and also need to know where to connect and which to connect
Thnx Ahead
Old Aug 13, 2007 | 05:43 PM
BiG1CeS's Avatar
ok
Thnx Ahead
what you need to do is run your rca's to a back speaker..... from there you need to run your remote on your amp to a fuses which will most likell be the head viser fuses so when you turn off your car your amp will turn off as well causin your speaker to turn off an not jump like crazy while the car is off.............
Old Aug 14, 2007 | 10:01 AM
Min5ki's Avatar
So the Remote wire connects to a fuse??? I thought it was a wire from the amp and i tap into it then run to amp
kmarqueling
Oct 3, 2015 01:14 AM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
asahrts
Sep 4, 2015 05:55 PM
