Amp Fuse Question
Old May 29, 2005 | 09:32 AM
NICKTL's Avatar
Amp Fuse Question
last night i blew my fuse, the one that is connected to my battery. when i first put in my sub my installer put a 40 in it and it blew. so he put in a 60. worked well for a few weeks till last night. i was wondering if putting a higher fuse, say an 80, would that effect anthing? is this good or bad? i crank it pretty loud sometimes when i am crusing the highway or when i had a bad day at work i like to get a "massage" on the ride home. thanks in advance.
Old May 29, 2005 | 09:37 AM
dark inspire's Avatar
El Presidente
What equipment are you running, and how much power is it drawing from the battery/alternator. There is a formula that will tell you what the right fuse is for the amount of power you are drawing. I just dont know where it is right now, but someone should know and i will look for it.
Old May 29, 2005 | 09:40 AM
NICKTL's Avatar
i am running a jl 500/1 pushing a jl 12w6v2.
Old Jun 25, 2005 | 11:55 PM
98_2.5_TL's Avatar
TL Enthusiast
Ok. assuming you're only running one amp ( the 500/1), look on your amp's connections. look for the fuses. I'm not sure of how many fuses/what amperage the fuses are, so I'm telling you to find it. find what the fuses are rated at, then multiply by the number of fuses. EXAMPLE = (30 Amps X 3). The number that you come up with is what you should use in the front by your battery. dont go any higher.
Old Jun 26, 2005 | 05:58 AM
miltcharlie's Avatar
Lord Ubber
I looked at his specs at the jlaudio website (and you could have done that yourself).
Anyways! His amp requires a 50amp fuse. So he needs a 50amp fuse at the battery.
06TLMatt
Oct 2, 2015 08:14 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
Pegon95
Sep 15, 2015 01:54 PM
datadr
Sep 12, 2015 09:12 PM
