amp...comments
amp...comments
- alpine MRPT130 ($129) 50x2
- sony XM752EQX ($127) 75x2 w/ 5band eq
anygood?
are kenwood amps any good? i am adding to my system in my sig.
i need help.
anygood?
i need help.
How about this one....
Around $250 or less.
• Max Power (EIAJ) 140Wx2 (4ohm; Stereo) 400Wx1 (Bridged 4ohm)
• 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 40Wx2 2ohm; Stereo (0.3% THD) 75x2 Bridged 4ohm; (0.3% THD) 150x1
•14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 60Wx2 2ohm; Stereo (0.3% THD) 100x2 Bridged 4ohm; (0.3% THD) 200x1
• S/N Ratio 100dBA
• Frequency Response: 10-50kHz
• 12dB HP/LP Crossover
(50-200Hz)
• Speaker Level Input
• Bass EQ Circuit
• Subsonic Filter (15/30Hz)TMRV-T407
• Extra Large Gold Plated Terminals with Wire Insert Capability
• Top Panel Power LED
• 4 Volt Input Capability
• Continuously Adjustable Crossovers
• DC Straight, STAR Topology & Duo-B Circuitry
• DC-DC/PWM MOSFET Power Supply
• S/N Ratio 100dBA
(50-200Hz)
• Bass EQ Circuit
JL audio sub (10"x2)
Perhaps a couple of these would be fine with you, since you asked for dual 10", instead of 12"
It would look like these with the box
JL Audio 10" Subwoofer (10W04) $99.99 or less
125-watt continuous power handling
Four-layer voice coil
VRC technology
4 ohms
Class leading excursion capability
VRC technology
4 ohms
alpine all the way!
just installed the alpine mrvf-357! kicks ass! sony makes fantastic home video/audio! i know, eveything in my house is sony!.there mobile euipment leaves much to be desired ! even the new xplod crap they are pushing , don't know why either? spend a little extra on the best, and you will never be dissatisfied ! check out my audio upgrades on my sig, the system sounds great, left the bose hu in coz the acura center console is a ***** to pull apart, and needs a custom install, in case you were wondering? peace...kman156
ive got the exact same amp MaxxT posted and another v12 amp
its the best out of the list you made. if your using it to run a sub, get the MRV-100M. SAME PRICE/SAME SIZE. dont pay more than $200 for it
when your car is running (driving), you are running the amps at 14.4V. when the car is off (in acc mode), you are running the amps at 12V.....this is all due to the alternator
in other words, you get more power when your driving
another thing, alpine amps are usually under rated. chances are youll get more power than what the specs say
i was thinking of that mono one mrv-100m. cuase i only want one sub. but just in case in the future, can you add another amp to that one? like connect it in parallel or something. instead of getting a 2 channel. i know the 2 channel is better the better choice, just want ot know.
real quick, for the alpine one, the MRV-100M [img]http://ecominet2.alpine-usa.com:7777/img/asb/mrv100mp.gif[/img
"MAX Power (at 14.4V,EIAJ)
Per channel into 2 ohms : 300W x 1
Per channel into 4 ohms : 240W x 1
RMS Power (at 12V,20Hz-200Hz)
Per channel into 2 ohms : 150W x 1 (0.3% THD)
Per channel into 4 ohms : 100W x 1 (0.08% THD)
RMS Power (at 14.4V,20Hz-200Hz)
Per channel into 2 ohms : 200W x 1 (0.3% THD)
Per channel into 4 ohms : 150W x 1 (0.08% THD)"
what do those frequencies mean? in bold? is it saying how low of a signal it can detect and amplify?
and this amp would be good for low bas right? thats what i need. low
the 100M is a dedicated subwoofer amp. if you have ANY question that you might need to use if for component speakers, get the 2 channel because this wont work. but you CAN use more than one sub with it
its only putting out one channel, the internal heat stays minimal....therefore keeping sound at its best
im not sure why those frequencies are in brackets in the power spec, but anyway.
my brochure here says that the crossover can be set to 50-200Hz. lets say you have the 100M connected to a sub, you have it at 50Hz(mine is at 55), the sub will be very mild and only hit when you really need it. you wont be able to tell where the sub is located. if everything else is set up properly, it'll feel like the sub is right beside you
now, if you have to set to 200Hz, the sub will ALWAYS hit. when you play music like Dido, the sub will constantly make thumping sounds like, grrrrrrrrrrrrrrrrrrrrrrrr. ya know?
you have to play with the setting and decide where you like it
heres a pic of my 100M and T407
you better appeciate this ****! lol
