AMP Blowout
Old May 9, 2001 | 01:37 PM
Guest
Guest
Posts: n/a
Unhappy AMP Blowout
Has anyone had problems with the TL's alternator and/or battery not being strong enough to run their aftermarket stereo?
I have 2 Precision Power amps, one 4x50. the other a mono amp 1x200. The mono amp has blown twice in 3 months!!?? What is wrong?? I really do not play the stereo that loud. Was the amp wired wrong?? Help!! Thanks!!!
Old May 9, 2001 | 04:05 PM
mr tl's Avatar
Post
ive got pretty much the same setup as you. only with alpine amps with slightly more power. no problems in 6 months
what guage wire are you running? when you say they blew, you mean the fuse on the amps right? what size fuse on the power wire?
Old May 10, 2001 | 12:37 AM
Guest
Guest
Posts: n/a
Angry
Mr. TL, I am not sure what the guage of the power wire is but it is made by Phoenix Gold. I feel that my installer has probably incorectly wired the system. My subwoofer amp is blown!
How do you correctly wire a amp to a subwoofer in the trunk, starting from the Bose HU? Should you bypass the EQ/amp unit above the HU? Is an inline converter needed? Do you bypass the Bose subwoofer amp behind the back seat?? Thanks!!!
Old May 10, 2001 | 10:56 AM
mr tl's Avatar
Post
you will definately need a line converter. that might be the problem is he didnt use one
you dont need to bypass any factory amps, but some people do anyway
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
