Which amp is better
IF im not mistaken orion makes ppi amps now if the ppi amp is the newer models. I have the old original model power class series and i know that is good. Im not to familar with the newer ones. But in attemp to answer ur question i think the ppi should be better.
yes orion and ppi are now made by the same manufacturer directed electronics inc.... but if i were choosing between amps i would have to say that i would go with the ppi since the cobalt is the lower class of orion...
I don't think that you are understanding the purpose of me asking what you have and what you will be using the amp with. The more information you rpovide (system specs with model numbers) the better our suggestions will be. What price can you get these amps for?
Bryan
Bryan
Originally posted by 360
thanks guys and my speakers are mb Quarts
MB Q Speakers I already have
Tweeter: 1" (25mm) Titanium dome
Woofer: 6½" (160mm) Polypropylene Cone
Crossover: 12 dB/Octave @ 2500Hz
Impedance: 4 Ohms (nominal)
Freq. Response: 45Hz to 32,000Hz
Power Range: 60watts (rms.) to 130watts
Sensitivity: 87dB (1 watt, 1 meter)
Woofer: 6x9" (16x230mm) Polypropylene
Mounting Depth: 2.75" Top Mount
3.44" Bottom Mount
Crossover: 12 dB/Octave @ 4500Hz
Freq. Response: 39Hz to 32,000Hz
Power Range: 60 watts (rms.) to 130 watts
amps
$ 160
Orion
CS200.4
200W 4/2 Ch Car Power Amp
ORION 200 watt 4/2 channel car power amplifier. Features 50 watts x 4 channels power @ 4 ohms or 70 watts x 4 channels @ 2 ohms or 50 watts x 2 channels & 140 watts x 1 channel @ 4 ohms or 140 watts x 2 channels @ 4 ohms output, redesigned heat sink, dual variable high pass X-over 50Hz to 1kHz, variable low pass X-over 30Hz to 250Hz and XBC/12 bass boost. Dimensions: 9.8" x 10.1" x 2".
PPI4240
for $200
240W 4/2 Channel Car Power Amp
PRECISION POWER 4/2 channel car power amplifier. Features 30 watts x 4 channels power @ 4 ohms, 60 watts x 4 channels @ 2 ohms or 120 watts power x 2 channel bridged @ 4 ohms, 4/5-way variable crossover with RCA outputs, Q-Bass bass boost, balanced differential input circuit, speaker lead high level inputs, high voltage input capability, gold plated RCA, speaker & power connectors and mixed mode stereo/mono operation.
3.44" Bottom Mount
amps
$ 160
Orion
CS200.4
PPI4240
for $200
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Pegon95
09-15-2015 01:54 PM
