Alternator Whine?
Old Oct 6, 2001 | 02:02 AM
acuradan69's Avatar
Alternator Whine?
Hello I have a 98 ACURA 2.3CL and I'm having problems with alternator whine. I have 0/1 gauge power running on the left side of the car and rcas on the right side of the car, and also a set of 12 gauge speaker wires on each side of the car(for components). I have my two amps grounded using 0/1 on the piece of metal right above where the trunk pass thru is and I am getting noise. It is secured with bolts and washers so I would figure its a tight ground. ANyone recommend anything to get rid of the alternator whine?(better ground? where?)
thanks
DAN
acuradan69@aol.com
98 2.3CL 1st gen
Old Oct 6, 2001 | 03:36 AM
SilverKnight's Avatar
Retired. Not available.
Originally posted by acuradan69:
<STRONG>Hello I have a 98 ACURA 2.3CL and I'm having problems with alternator whine. I have 0/1 gauge power running on the left side of the car and rcas on the right side of the car, and also a set of 12 gauge speaker wires on each side of the car(for components). I have my two amps grounded using 0/1 on the piece of metal right above where the trunk pass thru is and I am getting noise. It is secured with bolts and washers so I would figure its a tight ground. ANyone recommend anything to get rid of the alternator whine?(better ground? where?)
thanks
DAN
acuradan69@aol.com
98 2.3CL 1st gen</STRONG>
The only thing I would recomment is ground loop isolator. You can get one from Radio Shack for 15 bucks. But there is one guy said in the other thread that ground loop isolator just covers the noise I asked him to explain but haven't got his reply. In the mean time, get the GLI to see if you could get rid of it. You can always return it within 30 days.
Old Oct 6, 2001 | 10:57 PM
Woodsdaddy's Avatar
Everybody Wang Chung
You could just move the ground, it could be the ground on the head unit also, if it's aftermarket. It sounds like a ground problem though.
Old Oct 14, 2001 | 12:23 AM
LarryB's Avatar
Just a suggestion..
PAC Noise Filters - Alternator Noise Suppressor
http://www.crutchfield.com/cgi-bin/S...7ANS80&o=M&a=0
Old Oct 14, 2001 | 01:03 AM
Originally posted by LarryB
Just a suggestion..
Oh yeah, check the wiring to be sure your power cable and signal cables are not running side by side or crossing each other. Use shielded signal cables also help.
Old Oct 15, 2001 | 02:21 PM
icy CL's Avatar
i got the PAC ground loop things. they're a little less bulky than the ones from radio shack but i'm sure they work the same way. had to get 2 of them for my 4 channel amp. but now, no more alternator noise. i also moved my ground connection just to make sure. i grounded both my main amp and amp for the sub on the same grounding point and made sure i srcaped all the paint off with coarse sand paper.....just to get a good clean ground. also, i didn't notice any sound difference as far as quality with or without the ground loop isolators....except there's no more annoying alternator noise. thanks for the help, silverknight!!
Old Oct 15, 2001 | 09:16 PM
George, no problem man .. just ask away if you have any question. If I know, I'll talk if not, I'll shut.
BTW, I'm still waiting for an explaination regarding how ground loop isolator "wont solve the problem, just cover-up".
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
brboy
Oct 5, 2015 11:34 AM
mars
Sep 28, 2015 11:03 AM
