ALternator noise through speakers...HELP!
Old Feb 6, 2004 | 12:50 AM
JD22CL's Avatar
Rollin to GT in da CL
Hey
so ive got the alpine 7998, the shiznit when it comes to headunits...too bad i can hear my engine rev
anyone know the easy solution, i heard that cuz ive got an external amp i need some rca filters...
that sound accurate?
Old Feb 6, 2004 | 08:28 AM
NSXNEXT's Avatar
Sounds like a ground problem. Check all cabling.
Old Feb 6, 2004 | 08:51 AM
suXor's Avatar
Still trolling
Make sure your amp and head unit are grounded to the same point, and that your ground cable on your amp is as short as possible, and grounded to bare metal using a large bolt. Many use existing bolts in the trunk, or the seat belt bolts.
Old Feb 6, 2004 | 08:55 AM
BEETROOT's Avatar
Yeehaw
This would require running one of the grounds the length of the car. As long as they are both cleanly grounded to the frame you should be fine.
But as already stated, its probably your grounding causing the problem.
Also make sure your RCA's going to the amp aren't on the same side as the power/ground.
Old Feb 6, 2004 | 01:46 PM
Hobo's Avatar
Flap.
good quality wiring and soild ground points are they key.
make sure to remove the paint around the point to which you are grounding.
Old Feb 6, 2004 | 02:40 PM
JaySyn77's Avatar
Like mentioned above...check all your grounds. Also, make sure that your RCA cables are not running near the power cable.
Old Feb 6, 2004 | 02:50 PM
dallison's Avatar
registered pw
i have sometimes traced it to an amp that has faulty saudering
Old Feb 6, 2004 | 10:05 PM
Hobo's Avatar
Flap.
who is soldering their amp?
allen wrench anyone....? lol
Old Feb 7, 2004 | 12:43 AM
proaudio22's Avatar
-S namyaC-
He meant inside the amp.
Did you ground the chassis of the radio? There should be a 1/4" Fast-On tab on the back, connect that with the shortest wire possible to the best location you can find under the dash. You shouldn't have any amp grounds further than 2ft. Capacitor grounds don't matter as much.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
