Alternator noise
Old Aug 14, 2003 | 08:10 AM
liquid_x's Avatar
Alternator noise
I have this alternator whine every time I have the radio on at any volume. What can I do to get rid of it? This is on the factory HU btw.
Old Aug 14, 2003 | 08:34 PM
KyleWatson's Avatar
What speakers does the whine come from? What amp is installed, and are there any other amps in the car that are not having the sound? As much specific info as possible....
Old Aug 14, 2003 | 08:41 PM
JaySyn77's Avatar
Brian, make sure your ground is secure & on bare metal. Also, make sure your RCA cables and/or speaker wires are not running near the power or ground cable. That should cure the problem
Old Aug 21, 2003 | 01:56 PM
dallison's Avatar
registered pw
on my g/f's tl she had a whine also. i had checked the ground and power and rca's, the usual. decent rca's make a difference. but that was not the problem. this amp that we had purchased used had or still has ( b/c the amp is out of the car) the whining noise. what i did was disconnect each amp and crossover and 1 by 1 reconnect and turn on the car. now make sure u turn off car when connecting and start after the connection. i traced it to the amp. the way i found it was i turned off the gain and restarted the car. no noise, turned up the gain slowly and then i started to get some noise, even at the slightest increase in gain. so what i believe is that the soldering may be brittle or just older and i still ahve to get it repaired. check the amps and x-over
Old Aug 22, 2003 | 09:40 AM
NOLACLS's Avatar
Read that last few pages of the grounding wire thread in car talk....some people have said that the grounding wires the got also worked for the nise they used to have with the stero.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
