aftermarket head unit
T.O. Advance
want to put in an aftermarket. bose amp is a problem. if i remove the harness from the amp is that going to solve the problem or do i have to cut and rejoin wires as well?
Originally Posted by Rapmaster0
But I'm looking for a harness that goes from the stock radio to the amp so i can splice those? Does Metra make one of those?
I have no clue even what your situation or question is..
Former Sponsor
I think you would have to splice wires or either run new wires to the speakers. In any case is this for a CL? Are you willing to sell your harness if it fits and 06 TSX?
If you're looking to keep your Bose speakers, all you need is a Metra wiring harness. I bought one on eBay for under $10 and it works like a charm. If you're looking to change your speakers, then you will need to bypass the amp.
Former Sponsor
Running a high level audio signal into a BOSE amp induces clipping. Pushing your amp into clipping will burn up your amp and speakers like whoa. Not to mention your volume is maxxed out way too quick. It might work for you right now. But, a CL owner with the right parts is much happier.
Caffenine Addict
Originally Posted by uncald4
Wow. That was quick. It usually takes a couple of hours for somebody to offer bad info.
muhahha . you are God. Ive been trying to find the pac audio part all day. ive called Metra techs, all the audio shops in the area, and all my first class MECP cert buddies who said it had to be completely rewired and all the equipment needed to be replaced! I knew there was a way around swapping out all my speakers. I did this with the bose in my maxima.
Do we use OEM1 or OEM2. I have more then enough RCAs on my unit to use normal rca connections.. I guess it doesnt make a difference does it?
Would you mind PMing me?
Former Sponsor
Originally Posted by Tweek
muhahha . you are God. ......
What deck are you going to use?
I would have PM'd you but this is good info for everyone.
Caffenine Addict
You could use either one. I prefer the OEM-2 because it has more usable options. It has adjustable outputs for one. The OEM-2 also has "pass thru" wires for 12 volt, accessory, ground, illumination and antenna turn on. And it gives you a delayed "amp turn-on" output. This will keep your speakers from popping everytime you turn your car on and off.
The deck is a Pioneer DRH-P7800MP. Ive used a product similiar to the pac audio made by scosoche, when I integrated the bose amp on my maxima. What do the pass thru wires allow you to do?
Also, since i will be using an aftermarket decide I will be able to set up a mono amp and a sigle sub for some extra bass correct? I havent ever ran a amp integrator and also ran an amp on the same setup, but it seems possible since the deck will control the sub and the amp will use the preouts, or does the integrator use the rcas?
Former Sponsor
This is very good info, ive been searching all day for this info.
Caffenine Addict
The pass thru wires allow you to easily wire up your deck harness to your Metra harness. No jumping around hunting for wires. The OEM-2 uses the speaker outputs, not the RCA outs. But you can definately use your subwoofer RCA outs for an amp.
Last question, I could get my remote from the bose amp in the trunk correct?
And an off topic question... I see you have the 791xv on your TL. How bad was the install? What module did you use, 1100F? I printed out the wiring from work and doesnt seem all to bad really.
Former Sponsor
I knew it. Thank you. No one beleive me that there was a way without having to completely swap all the OEM equipment. For anyone else who is interested in this I will be doing this within the next week or two and will post a write up on it. The only thing i need to get started is the PAC integrator and the Pioneer integrator for my steering wheel controls which I can get from work.
Caffenine Addict
You work at Best Buy don't you?
Former Sponsor
We can't be friends.
You can get your remote turn on from the trunk..... but.... it's easier and better for you to run one straight from your deck harness.
Caffenine Addict
Installing the 791xv was a bitch. It took me 2 days. I used a 556uw for the immobilizer integration. Going into the drivers door for factory alarm disarm is a nightmare. I wouldn't trust your best installer to do this for you. When I worked at the BB as a SUP... I sent all my friends somewhere else. You might as well have a part time Rep1 install your shit. Sorry for the rant.....
Myself, I am definitely not the best installer in the world. I cannot fiberglass, dont like alarms, etc. I find myself as a better installer at best buy. I can install a deck and subs all day. Alarms can get very tricky and I wont do them. I let the know-it-alls figure it out. Anyways, I had planned to just run the remote line anyways instead of messing with the factory amp.
Thanks again for all your info, this thread should be stickied of made note of because it contains alot of valuable info.
Well its time for me to crash. I have to go in and try and help with a 791 on a 2004 Esclade EXT in the morning...
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Former Sponsor
Tweek... you're one step ahead of the game. You probably have more knowledge about the TL than anyone else in your bay. You're the best judge of your own work. Do a good job and know that you did a good job.
Good luck with that Esco.... It's pretty easy. As long as you have a 457GW.
Call me if you get stuck.
Caffenine Addict
-Sean
xsilverhawkx
09-28-2015 06:51 PM
Eggs999bacon
09-24-2015 10:08 AM
