Aftermarket Alarm with keyless
is there any way to wire the aftermarket alarm to work with the keyless fob that came with the car? i really dont way to carry two remotes areound. however the factory alarm sux.
1 Post
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Like said you would only need to carry the Aftermarket alarm remote. With a TL-S model you would give up the memory driver seat function from the factory remote. That function can still be used from the door. It all depends on what aftermarket alarm you get & what funtions. If you get remote start then your aftermarket remote would have that incorperated in it. The Master remote I have for my Clifford alarm allows you to adjust the alarms sensetivity if you want. I am sure if you get a window closer feature that would be in the remote also.
there are some companies, like viper and crimeguard? (crutchfield item), that make factory alarm add-ons. i think it's like a slave model which basically adds more sensors.
xsilverhawkx
09-28-2015 06:51 PM
