adding the system need a little help
Old Mar 15, 2004 | 06:41 PM
A-train_RENAMED's Avatar
i am adding an aftermarket radio with external amplifiers as well as new speakers. I would like you know how to find and identify the power,ground and remote turn on for the radio and a remote turn on I can use for the amps which will be in the trunk. thanks alot for your help.
The train
Old Mar 15, 2004 | 09:01 PM
vsokolov's Avatar
Radio 12v white + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on red/yellow + radio harness
Power Antenna yellow/green + radio harness
LF Speaker +/- lt. green - purple +,- stereo amplifier
RF Speaker +/- blue - red +,- stereo amplifier
LR Speaker +/- brown/white - red/yellow +,- stereo amplifier
RR Speaker +/- red/blue - yellow +,- stereo amplifier
Note: The stereo amplifier is in the passenger kick panel. The center channel speaker wires are green/white - blue/yellow. The subwoof speaker wires are yellow/black - lt. green/red.
Old Mar 16, 2004 | 01:26 PM
fsttyms1's Avatar
im not sure if its true for all years but my 2000 shows all the colors and what they are on the top of the radio
Old Mar 16, 2004 | 03:00 PM
AcuraX2's Avatar
If you use a wiring harness adapter, it will do all of the wire finding for you.
Old Mar 16, 2004 | 07:44 PM
Scott P's Avatar
Mobile Elec. Guru
since you are changing the radio you aren't going to need to think to hard about it, use the 98+ accord wire harness, it is a direct plug in. then the only wire you will need to tap off of it will be your remote turn on for your amps. you can use either the red wire on the 98+ accord harness, or you can use the labeled remote turn on from the new radio's harness. Being as you have a 2000TL you won't have to worry about the stock amps at all, they will be eliminated from the equation the moment you switch the radio.
Old Mar 17, 2004 | 05:27 PM
thanks alot guys. the 98+ accord wiring harness worked perfect. Ill post pics when i get everything done and installed.
thanks again for the help
Mike Pilipenko
Mar 26, 2024 09:21 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
Cgannotti
Sep 25, 2015 05:04 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
