Adding New HU and Can't Get Everything to Work
Old Aug 9, 2006 | 08:21 PM
DDiggalo's Avatar
4th Gear
Ok so here's the deal. I bought a new HU (JVC KD-AVX2). I want to use it to push my speakers. But I can’t figure out how to bypass the factory amp so I do not need to use it.
When all plugs are plugged in where they originally were (except the one from factory HU to New HU) I've gotten the FM to work then when I try a cd the cd shows it's playing but no sound coming out . So I unplugged the plugs going to the amp but when I do that the New HU turns on but no sounds come out even on FM.
So in a nutshell I would like to not use the factory amp and just use the New HU and speakers. I've looked al over for some picturs and diagrams but the one I’ve found haven't really helped any.
I'm also trying to keep the back lighting of the A/C controls working even thought the plug in the back is now going to the New HU. I figured splitting the illumination wire and some how fixing it to he corresponding spot behind the factory HU could work.
Old Aug 9, 2006 | 08:40 PM
DDiggalo's Avatar
4th Gear
Oh almost for got I have 04' TSX
Old Aug 10, 2006 | 03:36 AM
aznxtallxboy's Avatar
switch blue wire w/ blue.white wire. it should work then
Old Aug 10, 2006 | 12:54 PM
Tsx536's Avatar
Rep'n Taxbrain.com
So you get sound through FM radio, but you get no sound with the CD player?
That's pretty strange.
Break down your setup a little more.
1) You're not using the Factory HU, and you're not using the factory amp, correct?
2) I'm assuming, you're going from the JVC deck to your amp via RCA, then after that, how are the speakers connected to the amp? Where did you splice into their signal?
Old Aug 10, 2006 | 02:16 PM
DDiggalo's Avatar
4th Gear
ok the way i had it when only the fm worked was the jvc HU threw the acura harness adapter then i beleave that goes threw the factory amp to the speakers. what i want to do is not use the factory amp at all and use the JVC HU built in amp to push the speakers for right now. down the line i may get some amp(s) for my speakers when i install a sub later on.
i tryed unplugging the plugs behind the amp and leave them unplugged (but nothing worked all i got was power and no sound at all) from what i've seen in diagrams those two have to be conected some how wether threw the amp or splicing the wires and making the go threw each other w/o the amp
Old Aug 11, 2006 | 01:09 PM
DDiggalo's Avatar
4th Gear
Well I got everything to pretty much work a few wires i didn't connnect good enugh but everything works. I decided to unplug the plug in back of the factory amp and splided the wires that would got to these spots and conected them together.
http://www.chrishorne.com/albums/aud...stem.sized.jpg
B1-A3/A4 (+) LEFT FRONT B8-A13/A14 (-)
B3-A6/A8 (+) LEFT REAR B10-A16/A18 (-)
B4-A1/A2 (+) RIGHT FRONT B11-A11/A12 (-)
B6-A5/A7 (+) RIGHT REAR B13-A`5/A17 (-)
The only thing was I don't know what the shieldings are ( B2, B5, B9 B12) Can anyone inlighten me on what they are and if they are nessecary for anything?
snorf
Nov 4, 2019 06:44 AM
01CLOwner
Oct 9, 2015 01:07 PM
acurajj
Sep 19, 2015 03:47 PM
Pegon95
Sep 15, 2015 01:54 PM
