Adding an Alpine amp
Old Mar 22, 2001 | 03:48 PM
dlp's Avatar
dlp
How easy would it be to add an Alpine amp to the sound system? The one I have would only allow 4 of the 6 speakers, bt it would be nice to add it to the middle and back, or maybe the fron and back if the fronts can handle it... Can't I just plug the speakers intot he amp, and the amp outlet into the system? Thanks
2001 CL Type S w/ NAV & Spoiler. San Marino Red/Parchment int. Purchased 2/28/01.
http://albums.photopoint.com/j/AlbumIndex?u=1584587&a=12058921
Old Mar 22, 2001 | 03:56 PM
FDao's Avatar
dlp,
Scalbert, I believe did an installation just like you mentioned. He hooked the Amp in line with the existing Bose Amp; that is the outputs from the Bose Amp goes to the inputs of the Aftermarket Amp, and the output of that amp goes to the speakers.
Frank
01-S White/Parchment
Comptech Sways & Springs
Old Mar 22, 2001 | 04:14 PM
dlp's Avatar
dlp
thanks fdao..
does anyone know where the Bose amp is located? is it behind the dash, or to the side front area...
Old Mar 22, 2001 | 04:18 PM
Ult's Avatar
Ult
I believe it's on the right side of the trunk -- passenger-- behind the right side trim panel. There should be 3 or 4 mounting bolts holding the amp.
-Ult
Old Mar 22, 2001 | 07:36 PM
mishka420's Avatar
<font face="Verdana, Arial" size="2">Originally posted by dlp:
thanks fdao..
</font>
Its in the trunk..........behind the Navi.
01' CL Type-S, Navigation, Spoiler
4% tint on the backs and 34% on the fronts
Eibach Pro-Kit Springs (2" Drop)
Old Mar 22, 2001 | 07:44 PM
WebToker's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mishka420:
</font>
Its in the trunk....not behind the navi... it is behind the jack on the right hand side.
2001 Acura 3.2 CL Type-S
Comptech Springs
Comptech Exhaust
Apexi V-AFC
AEM CAI
Old Mar 22, 2001 | 07:56 PM
millenniumCL-S's Avatar
Is there any noise in the system if you added another amp to the bose amp? And how are you runnig the power wire and the RCA's... Cause i was thinking about adding a sub to the current system. Has anyone done it yet?
CL-S, 35-20% tint, stock looking for mods...
Old Mar 22, 2001 | 08:02 PM
LarryB's Avatar
you can add a sub pretty easy by tapping into the 2 rear speakers. Only problem is you need to cut. I hate cutting . But i will and does work.
2001 Silver 3.2 CL-P
Tints, piaa road lamps, hyper white all around, custom eyebrows, tl-s cup holders
Old Mar 22, 2001 | 08:05 PM
X3.2CLSX's Avatar
White Lightning
whoa whoa whoa, whats this im hearing already, Correct me if im wrong guys,
You guys buy another amp and add it to the bose amp, or do you replace the amp with a new amp? Tell me whats up with that? Ive been meaning to get a system.
NightHawk Black CL-S
Black Interior
Clear Headlights
Nokyo Halogen Bulb Artic White
Coming Soon: AEM Cold Air Induction
Old Mar 22, 2001 | 08:07 PM
X3.2CLSX's Avatar
White Lightning
Do you have to get a specific kind of amp? How much watts can our bose speakers handle? I dont want to blow them
Black Interior
Clear Headlights
Old Mar 22, 2001 | 08:08 PM
WebToker's Avatar
I ran the power wire from the battery and the remote wire from the stock amp so the sub amp turns on with the stereo.
Comptech Springs
Comptech Exhaust
Apexi V-AFC
AEM CAI
Old Mar 22, 2001 | 08:12 PM
WebToker's Avatar
<font face="Verdana, Arial" size="2">Originally posted by WebToker:
</font>
Here are the wire schematics for the amp and stock head unit. They make things a lot more flexible...
http://albums.photopoint.com/j/Album...525&a=10925906
Comptech Springs
Comptech Exhaust
Apexi V-AFC
AEM CAI
Old Apr 14, 2001 | 06:20 AM
drod267's Avatar
Can anyone tell me exactly how to get to the stock amp??
Thanks.
Old Apr 14, 2001 | 03:22 PM
LarryB's Avatar
To get access to stock amp you must move away the trunk carpeting on the passenger side. To do this you must remove the black platic piece right in the middle of the locking mechanism, then remove (plastic) screw on the sides of the trunk. Then bend it away. It will be about middle of the right side of the trunk. Once your there it is pretty easy to figure out.
Tints, piaa road lamps, hyper white all around, custom eyebrows, tl-s cup holders, Acura-CL.com stickers
Old Apr 15, 2001 | 08:21 PM
drod267's Avatar
Thanks LarryB!!
I found it. One more question if you don't mind. I have the schematics and info on the wires that connect to the amp. I can just solder RCA connectors onto the audio signal wires coming from the deck and we're all set to plug into an amp, right?? It seems like this would be the case but I just want to be sure.
Thanks!
Old Apr 16, 2001 | 12:53 AM
LarryB's Avatar
Yes you can
4drviper
Apr 23, 2025 07:13 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
