Accessing the TSX kick panel for audio installs
Old Feb 21, 2006 | 11:33 PM
Yui's Avatar
Yui
Hi all,
I've seen lots of posts referencing use of the right kick panel for splicing AV cables. Does anyone have documentation for how to do this? For starters, which one exactly is the right kick panel? Photos would be much appreciated as well.
Thanks!
Old Feb 22, 2006 | 12:09 AM
CJams's Avatar
Guinea Pig
Sorry, no pics on the web. But basically what you do is pull the black threshold piece up on the passenger side. That would be that black plastic piece that sits between the carpet and the "Acura" skid plate deal you see when you open the door(On the drivers side it has the trunk release and gas lid release). Start from the rear and pull up in about 3 places till you get to the front of it.
Once that's out, you can pretty much pull the kick panel out by grabbing it from the bottom and pulling straight out.
The plug you want is right there when you get it off.
Old Feb 22, 2006 | 01:28 AM
Spoon's Avatar
^^^cjams instructions
oddly enough, I do have a pic of the panel
Old Feb 22, 2006 | 08:15 PM
Tsx536's Avatar
Rep'n Taxbrain.com
There's a plastic connector on that kick panel too. Make sure to be a little careful when you pull it off. It should pop right off though. Also make sure that it's lined up when you reinstall it.
Old Feb 25, 2006 | 03:24 PM
Yui's Avatar
Yui
Awesome, thanks for the tips. I'll go take a look at it when I get some time =)
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
