6 CD changer from Accord compatible with 00 TL?
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Are the 6 CD changer in the newer model Accords compatible with 00 TL? I have a 2000 TL which came with a single CD player with cassette. I know newer models come with 6 CD changer in the dash. I have a friend who upgraded his stock 6 CD changer in his Accord to aftermarket and am wondering if I can hook that up to my TL.
Other related q:
1. How much should I pay him for the stock 6 CD changer?
2. How much would the labor be to install it on my TL?
Any info will help. Thanks in advance.
Sorry if this has been discussed about before.
Other related q:
what year accord? it's the oem honda changer? if so, it probably will work and should plug right into the tl headunit without an adapter. if it's a real alpine changer, make sure it is a chm series and not a cda one...you'll also need an adapter.
ok let me get this right you want want take out the stock headunit and put a new model accord headunit in your car... i would say that it should plug right in and depending on what accord modle you are talking about (ie w/ bose without/ bose you may have to do some slight modifications to get the stock sub to work... but if i remember correctly the stock accord headunits are square and the tl headunits have a slant on each side... so then you would need to make a faceplate... and if you are going to go thru all this i would say just spend a little more cheddar and get an aftermarket headunit..... but with the right about of time and money any thing can be done..... as for how much you should pay him i would say no more than a couple hundred dollars....if that... personally if i was you and that is all you want is the 6 disc in dash headunit i would look at trying to get a 2002 and up stock headunit... simple plug and play upgrade... just my 2 cents....
BlingBling INSPIRE 32V
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
For a trunk mounted Alpine CD changer (CHM-S620), are the adapters made for a 1999 Honda (any model) compatible with a 1999 TL? I'm trying to figure out if a.) this changer will work with my TL, and b.) if I can use a Honda adapter.
Received 1,080 Likes
Originally posted by lhommec13
I think I figured out my previous question, but now I have another simple one. Is the interface on the back of the radio (1999 TL) a round 8 pin or a square 14 pin?
adreano17
09-29-2015 08:48 AM
