4 amps on a Acura Tsx !!!!!!!!!!!
Old May 27, 2005 | 11:44 AM
castillo183's Avatar
Okay people i am new here so i have to get hang of this thing. Anyway got any suggestion about putting a whole new aftermarket sound system in a tsx. My Aftermarket system that i want to put is 2 1"R25 kicker tweeters and for the speaker they are 4 kicker R6c Midrange speakers and For the rear they are JBL GTO 963.
The amp that I want to use for the tweeters is a 2 channel Alphasonik rated at 100 watts rms, Second Amp is a 4 channel Alphasonik rated at 100 watted Rms and for the rear same 2 channel amp rated at 100 watts rms.
To finish off This sound system a Lanzar 10 channel Crossover with MA Audio 15 band Equalizer and a Blitz 25 farad Capicator.
Old May 27, 2005 | 12:14 PM
elduderino's Avatar
VP Electricity
Seems like a lot of money and not a lot of sound quality, but it should play loud, which is what I suspect you want. I suspect it will have engine noise and be bright and not very good sounding.
For $2900 I could put a very nice, loud system with subs in your car and a custom install, and you still could buy some CD's after.
Old May 27, 2005 | 12:20 PM
the Problem this that u are in the other side of the country but what is your opinon what system should i get
Old May 27, 2005 | 12:21 PM
I wanted to Get Beyma W6 for midrange and Keep the Kicker r25 for tweeter and jbl 2 ways speakers and run a separted Crossover and 4 amps.
Old May 27, 2005 | 12:25 PM
But, Like you Said elduderino i just getting the parts and then i going to take to a Audio shop so they could do the rest.
Old May 27, 2005 | 01:04 PM
matelot's Avatar
Originally Posted by castillo183
Okay people i am new here so i have to get hang of this thing.....
dont get addicted
Old May 27, 2005 | 04:14 PM
elduderino's Avatar
VP Electricity
My suggestions:
1) If you are looking for maximum SPL (volume) then Kicker probably works well. It's not going to sound very good from a hi-fi perspective. WHat do you want?
2) If you mix and match a lot of gear you need a pro to make it work or you need to know a lot.
3) Why four amps?
Old May 27, 2005 | 04:24 PM
Well I think i want Loudness and the reason why i need the four amp so i can get the maxium Volume out of each speaker but if i want to go to hifi what is your reccomenation if i wanted some Loud And Clear at the same time ?
Old May 27, 2005 | 05:12 PM
vasu's Avatar
4 is better than 1
Old May 27, 2005 | 09:35 PM
the thing is that i am going to have a pro do my installlation i just want HIGH MID LOW at the same time that was the reason why i pick this speaker Kicker R6C MIDRANGE
Old May 27, 2005 | 10:40 PM
vidoprof's Avatar
ok for $3000 you could get a VERY GOOD sounding AND LOUD system. Hell I used to have 2 eclipse aluminums (12's), and a set of DLS components up front with DLS amps and it was under that amount and was LOUD..
Get good equipment and the LOUD WILL Come. "build it and they will come'
Ryan
Hell buy all JL stuff and you can still come under that amount and get good SQ and loud.
or drive x country and save and have eld do the install, might come close to $3000
Old May 27, 2005 | 11:46 PM
problem is i live in new york I would do it i just want Something LOUD SO I CAN GET THE ATTENTION
Old May 28, 2005 | 12:11 AM
dark inspire's Avatar
El Presidente
i dont think the kind of attention u get with crap sound coming out of ur car is the type of attention you want
Old May 28, 2005 | 01:50 AM
In your Opinnon What should i Get for the price of 3000 dollars , what type of setup and what about Beyma or Focal speakers
Old May 28, 2005 | 08:30 AM
vasu's Avatar
If you live in new york and are going to get someone to install it anyway, why not drive down to new jersey and get (board member/sponsor/retailer) StreetEffectz to do the work?
Old May 28, 2005 | 09:04 AM
StreetEffectz's Avatar
Thanks for the recommendation
We are back in the store this coming Tuesday (took a long weekend for the holiday) - give us a buzz at 732.388.7000 or email streeteffectz@streeteffectz.com - we'll set you up with exactly what you are looking for
Old May 28, 2005 | 09:28 AM
El Presidente
and when the man says exactly, he means EXACTLY.
Old May 28, 2005 | 09:49 AM
zzzed's Avatar
tsxer
whatever you do, stay away from the lanzer/ma audio part of the deal......
Old May 28, 2005 | 10:40 AM
I didnt know trying to bulid a sound system can so f--king hard lol
Old May 28, 2005 | 10:43 AM
the problem i am just following one of my friend Suggestion. He Kicker Midrange and kicker Solobaric and Tweeters mostly the whole componet set and he was using a Pioneer dvd 6400 and car was freaking loud and clear !
Old May 28, 2005 | 11:03 AM
elduderino's Avatar
VP Electricity
I think the parental "if he jumped off of a bridge" saying might come into play here.
Listen to StreetEffectz and you'll be fine.
Old May 28, 2005 | 11:10 AM
El Presidente
next time someone asks me that, im gonna say yeah....w/a bunjee chord
yeah StreetEffectz knows his stuff, some guidance from him and you will be set w/ good sound and loud. I dont think you will regret it.
Old May 28, 2005 | 12:27 PM
cool but the 3000 dollars that is all parts with labor some audio shop told me
Front Tweeter : Kicker r25
power range : 8-150 watts rms
freq:3.5khz-22khz
Midrange : Kicker r6c (6.5" speaker)
power range : 100 watts rms
freq: 40hz-4.5khz
For the 6x9: JBL GTO 2 way 963
Power Range: 5-175 watts rms
freq: 20hz-22khz
SUBS :2ALPHASONIK 12" ALPHA800
power range : 900 watts rms 2 ohms
freq: 30hz-250hz
The Amp that is going to be use
Tweeter: Alphasonik Q-Reference 2150
2 channel 100 watts rms at 4 ohms
Midrange: Alphasonik PM4150A
4x 150 rms watts at 4 ohm
6x9 speaker: Alphasonik Q-Reference 2150
2 channel at 100 watts 4 ohm
Subs: Alphasonik PMA 1000 HCA
2x900 watts 2 ohm
Equalizer : MA AUDIO 15 Band
Crossover: Lanzar 10 channel Crossover
AMP KIT : 0 Gauge with Digital Metter
Head UNit : Stock Navi W/ Radio
this is the setup
Old May 28, 2005 | 12:29 PM
the amps are like the most expensive the speakers i already have them a friend of my got them for me the amp i only have two i have to get the 4 channel and the sub one
Old May 28, 2005 | 04:45 PM
Playa178's Avatar
For 3 grand you can do kick panel pods, 3-way seps up front, midbass' in back and 3 12s with 2-3 amps and a x-over...
that'd be loud.
Old May 28, 2005 | 06:38 PM
CCColtsicehockey's Avatar
why wouldnt you do a component setup up front instead of seperate tweeters and seperate door speakers
Old May 28, 2005 | 07:41 PM
OK, what equipment did you already purchase?
Old May 28, 2005 | 08:45 PM
i already purchase the Speakers and the tweeter and the 2 channel amp i should be getting the subs and Amp Next week or 2 week
Old May 29, 2005 | 05:16 AM
vasu's Avatar
if you already made your decision and bought all this gear, then why are you asking for recommendations?
you've already got most of your equipment purchased or ordered ... not sure there's much more we can do for you here
Old May 29, 2005 | 09:43 AM
El Presidente
Except maybe aid in the installation to some how make it sound better than usual
Old May 29, 2005 | 12:02 PM
yea i think the aid that i need to make it sound better
Old May 29, 2005 | 12:03 PM
once i get it how can i make every speaker do it job high mid low ?
AndrewS
19
Mar 14, 2024 06:59 PM
jriv7
May 8, 2020 05:50 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Heyzuez20
Oct 14, 2015 07:18 AM
