3G Amp Sub Stock HU Question
Old Jan 18, 2009 | 11:55 PM
rockstar143's Avatar
Smile 3G Amp Sub Stock HU Question
Ok...I have read through ALL of the posts and threads and cannot find a definitive answer to my question.
It goes as follows:
I have an 04 TL Non-Navi.
I would like to add my aftermarket capacitor, amplifier and 2 12" subs. I bought an LOC today and would like some guidance. I would like to know where the stock amplifer for the sub is located. What color wire is the remote wire for the stock sub (so that I can wire it up and have the aftermarket amp come on ONLY when the radio is turned on).
Do I need to disconnect the stock amp/remove the stock subwoofer (I've read that this will act as a port for the bass). I have a decent amount of knowledge but would like some information to avoid any unneccessary removal or wiring confusion. I know I'm doing fused power wire from battery, ground to chassis, remote turn on from stock wiring and LOC from 2 speaker wires to stock subwoofer.
Anybodies expertise and information in this area will be GREATLY appreciated.
Thank you much,
Jeremy.
Old Jan 19, 2009 | 08:19 AM
Pretty please!?!!! Anybody?
Old Jan 19, 2009 | 12:57 PM
figured it out...thanks anyway all. anybody needs any info, let me know.
Old Feb 4, 2009 | 08:16 AM
pgapeles's Avatar
System Install
Would you mind telling me how you were able to hook up an aftermarket amplifier to the OE system? What's a LOC?
Old Feb 4, 2009 | 08:36 AM
Sure, line output converter...can be purchased at best buy for about 27 bucks. It lets you tap into the wires coming from the stock subwoofer and connect the RCA's to it to go to the amp. Run fused power to battery, ground and remote wire (I ran from the orange wire going to the stock amp located in the right passenger footwell. It's the stock remote turn on). Then that's it...it should be all good to go. Pretty simple.
Old Apr 1, 2009 | 01:16 PM
jdubub's Avatar
where did you run the power wire for the sub amp?
Old Apr 20, 2009 | 01:11 AM
h2point2's Avatar
is this what you bought?
http://www.bestbuy.com/site/olspage....=1218015169429
what wires did you tap into for signal?
Old Apr 20, 2009 | 06:51 AM
Yes...any line output converter like that will work. Check out davidnavone.com for really good quality ones...ended up using a 4 channel one from that website to hookup for mids and highs (stock couldn't keep up with that much bass).
Then...splice the LOC into the stock sub wiring (removed factory sub since it just ends up sounding like muffled weak bass) and run your fused POS from the battery, ground, and remote from any accessory fuse (although I opted to tie into the remote turn on wire for the factory amp located in the passenger footwell).
GL!
Old Apr 22, 2009 | 12:06 AM
h2point2's Avatar
ok i feel real stupid lol, ive wired up all my other cars but never had anything like the tl. there are 5 wires on that loc. which wires do i hook to the stock sub harness, and is the 5th wire a ground for the loc?
Old Apr 22, 2009 | 07:28 AM
I believe so...
the other 4 wires are for pos/neg and left and right (2 channel)
For the sub, since it's only one channel you can just pick one set of them since the TL has a dedicated subwoofer channel anyway that is controllable from the headunit, it won't matter.
Just make sure to use the same...whether it's left or right, use pos and neg to whichever side you choose
Old Apr 22, 2009 | 07:53 AM
Jonesi's Avatar
rockstar thanks for sharing and helping out other members..!
Old Apr 22, 2009 | 08:25 AM
Anytime! I know I appreciate it when people have come through for me so I figure I'll share whatever I can!
Have a good one!
J.
Old May 14, 2009 | 11:35 PM
h2point2's Avatar
ok im doing my amp install right now and if i check that orange wire for my stock amp its hot when car is off but dead when key is turned i dont understand it all. any help?
Old May 15, 2009 | 06:02 AM
No idea! You definitely don't HAVE to use that wire as the remote. Even with it, my amps are all on when the car is on regardless of the radio so you might as well just pick an accessory fuse to tie into to get the remote signal to come one.
Just to double check though...we are talking orange wire BEFORE the amp, right?! Did you unplug it to test it out?
Old May 15, 2009 | 07:16 AM
Jonesi's Avatar
Weird... very weird... Let us know what you figure out..
Old May 15, 2009 | 07:21 AM
I AM correct about the remote wire being ORANGE, right? Did I remember it correctly?
If for some reason you can't figure that wire out...use your tester on ALL the wires going INTO the amp until you get one that has power when the key is on ACC.
Old May 15, 2009 | 07:31 AM
Jonesi's Avatar
Did you find a write up on it? I got nothing when searching.. I saw the thread I have in the DIY for wires in the passenger kick panel but that's it..
https://acurazine.com/forums/showpos...7&postcount=13
Old May 15, 2009 | 07:34 AM
Come to think of it, I'm not really sure where I found that! I guess I can take my kick panel off and take a look at what wire is ACTUALLY the remote wire.
Stay tuned...gotta hustle to get to the coldplay concert tonight, but hold out and I'll get back to you.
Old May 15, 2009 | 12:34 PM
h2point2's Avatar
coldplay concert heck yea i was going to go when they came here but sold out.
ok i checked everywire!! to are the orange wire. then on the other side of the plug there is a wire that is always hot. i just used a (addafuse link) and hooked the remote wire up to that in my accessory spot #32
Old May 15, 2009 | 12:41 PM
Alright! That'll work.
To be honest..I almost passed...I saw NIN last week and have DMB in 2 months. Glad I didn't though...I'm really looking forward to it.
How about this...maybe it doesn't have signal if it's not connected to the amp? Like...did you unplug the plug and then test it? I know the TL stock amp is complex about everything being plugged in car turned on. Learned the hard way when I was trying to get my aftermarket amp to have sound...it wouldnt' work till I turned the car completely ON. And...come to think of it...I don't know if I even checked the orange wire before using it for remote because I had read SOMEWHERE that that was the correct wire and everything turned on. Well...sounds like you got it resolved anyway so Kudos!
J.
handsom-hustla
Nov 13, 2015 05:04 PM
Pegon95
Sep 15, 2015 01:54 PM
datadr
Sep 12, 2015 09:12 PM
yahelou
Sep 6, 2015 09:12 PM
