2nd Question for any audiophile...
Guest
Posts: n/a
Just use a screwdriver blade to CAREFULLY pry up the fabric-wrapped cover on the parcel shelf. Once it's lifted, GENTLY pull up to clear the tabs that the cover locks onto. After the cover is off, you'll see that the sub is held on by 4 locknuts. Disconnect the wire to the sub terminal from inside the trunk, and then unscrew the locknuts; lift the sub driver off the mounting screws...
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
