TL: 2g TL Wiring question
Old Jan 2, 2011 | 02:23 PM
swllen_cu's Avatar
Hey guys new owner of a 01 TL and looking to transfer all my stereo equipment from my 6th gen accord to the TL, but had a quick question..
- If I were to wire up a 4 channel amp for my speakers, where would I tap into the wire harness to get signals to the speakers without running new wires through the doors? Could I just get the wires coming to the factory bose amp or do I just tap into the wiring harness in the back of the headunit?
I've tried searching, but couldn'tfind any real solid answers...
Old Jan 2, 2011 | 02:31 PM
swllen_cu's Avatar
Forgot to add that I'm gonna be adding an aftermarket HU in it too
Old Jan 3, 2011 | 08:07 PM
Jonesi's Avatar
I believe you want to catch the output side of the amp.
Old May 28, 2011 | 01:40 AM
99AcuraTL03's Avatar
is too sexy for his shirt
did you ever figure this out? facing the same problem now
Old May 28, 2011 | 01:24 PM
dykyy's Avatar
If you are going to be installing a new HU then why are you worrying about finding the signal?! You will connect everything with manual that you will get with the harness for your deck. Then you are running rca's to the amp.
If you were installing a LOC then you would just tap into the rear speaker channels... Either one. Or both for 4 channels.
Old May 28, 2011 | 03:54 PM
so basically I'm gonna need to run new speaker wire from the amp to the doors
Old May 28, 2011 | 06:16 PM
dykyy's Avatar
^well if you want it to sound better and be much louder than right now, then yes. I did it a few weeks ago. Running the wires was fairly easy, other than door back to cabin. But i simplified the install and it took me literally a few hours to run both sides (taking my time)... If u have any questions, lemmme know.
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
VA2000TL
Oct 2, 2015 08:26 AM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
