MDX: 2009 Acura MDX, Remote Start, Activation input
Old Jan 26, 2020 | 09:19 PM
Nate Johnson's Avatar
9th Gear
Long story short:
I am trying to get an Avital 4300L remote start (utilizes factory FOB) and PKALL installed in my wife's 2009 Acura MDX.
The PKALL is working flawlessly, its the 4300L that I am struggling with.
I am using the activation input from the door lock switch (pink wire, +). However, even though it the door lock switch, it does not "see" the FOB being pressed (Sorry, I have been out of the install game for 15+ years so used to older tech). I can sit in the car and press the lock button on the door 3 times and the remote start activates. It deactivates with a hood pop or brake press, so everything is wired correctly.
Does anyone know where to find either a positive or negative door lock wire From the FOB, not the door.... Does this even exist?? Im assuming (I am sure I am using improper terminology here) there must be an antenna for the factory fob which has a wire harness to the BCM or other control module?! I should be able to tap into that wiring.. Maybe someone has access to the wiring diagrams for this???
Thanks!
AMIC
3G MDX (2014-2020)
Dec 22, 2014 11:24 AM
MANswers
Oct 5, 2012 12:36 PM
WhySoAsian
Nov 14, 2011 10:19 PM
mola
1G TL (1996-1998)
Sep 21, 2005 01:30 PM
mp3coupe
Apr 4, 2003 05:38 PM
