TL: Adding Subwoofers
Adding Subwoofers
I have a 2002 TL Type S .... I read the DIY of hooking up the aftermarket amp and the subs... But there are a few things I'm planning to use that are different from the write..
I have a lanzar 1200 watt 2 channel amp and a box with 2 MTX Thunder 5500 12s.... And a Line Out Conveter.
Question here is ... How do I hook up my amp in conjuction to my subs.?.. I know my subs can handle 2 ohms but I'm confused if things will work since there was only OEM sub and a 1 ohm amp.
In general I'm asking will taking the mono signal through the LOC ( wires twisted ) mess up my subs & is the remote sign strong enough to keep the amp on... I read it's 9 volts ... I think aftermarket HU gives 12..
I'm scared I might ruin my amp or my subs...
Also I'll be powering straight from the battery with a Amp + Cap Kit.. Thanks..
clintcoin
21
02-24-2016 08:05 PM
Shawn S
12-27-2001 10:32 PM
