2001 Acura CL Vehicle Wiring Information
Honkey
This may come in handy from time to time...and this took me FOREVER to type with all the colors
Blue=Item
Red=Wire Color
Green=Location
Purple=Polarity
Also, pay attention to the special notes at the bottom of the page (ie. *1, *2, *3...)
12v---White
---ignition harness+
Starter---Black/White
---Ignition Harness+
Ignition---Black/Yellow
Accessory---Yellow
Power Lock---Black/Blue
---Passanger Fuse Box *1-
Power Unlock---Orange
Lock Motor---White/Red
---Drivers Fuse Box *2
Unlock Motor---Yellow
Disarm Defeat---Lt. Green/Red
---Passenger MUX Module *3
Parking Lights +---Red/Black
---Passenger Kick Panel
Parking Lights ----Red/Yellow
---Left of Steering Column
Head Lights---Blue/Red
---Left of Steering Column-
Door Trigger---Black/White
---Passenger Fuse Box-
Dome Supervision---Use Door Trigger
Trunk Pin---Blue/Green
---Drivers Fuse Box-
Hood Pin---Yellow
Trunk Release---White
---Passanger MUX Module *3+
Factory Alarm Arm---Arms With Lock
Factory Alarm Disarm---Disarms With Lock
Disarm No Unlock---Blue
---Drivers Door Key Cylinder-
Tachometer---BLUE
---DRIVERS SHOCK TOWER *4
Speed Sensor---Blue/White
---Cruise Control Module *5
Brake Wire---White/Black
---Brake Switch+
Horn Trigger---Lt. Green/Blue
---Steering Column-
Wipers---Blue and Blue/Yellow
LF Window Up/Down---red/yel - red/blue
---Drivers Window Switch
RF Window Up/Down---Blue/Wht - Blue/Yel
---RF Window Switch
SunRoof Open/Close---Grn/Yel - Grn/Red
---Relays Left of Fuse Box
Radio 12v---White/Yellow
---Radio+
Radio Ground---Black
---Radio-
Radio Switch---White/Red
---Radio+
Radio Illumination---Red/Black
---Radio+
LF Speaker---Blue/Grn - Gry/Blk
---At Speaker
RF Speaker---Red/Grn - Brn/Blk
---At Speaker
LR Speaker---Blue/Yel - Gry/Wht
---At Speaker
RR Speaker---Red/Yel - Brn/Wht
---At Speaker
Note: This vehicle has an immobilizer system that needs to by bypassed with adding a remote start.
*1 Located in the Green 20-pin connector. Use the key switch in the passanger door to test.
*2 Located in the green 18-pin connector
*3 The Passenger MUX module is located behing the glove box
*4 In the 2-pin connector near the air intake on the drivers side shock tower
*5 The cruise control module is to the right of the steering column.
Blue=Item
Red=Wire Color
Green=Location
Purple=Polarity
12v---White
Accessory---Yellow
Hood Pin---Yellow
Tachometer---BLUE
---Brake Switch+
---Steering Column-
---RF Window Switch
---Radio+
---Radio-
---Radio+
---Radio+
---At Speaker
---At Speaker
---At Speaker
---At Speaker
Soul_Deamon
11-13-2018 04:44 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
