1 or 2 boxes?
Old Feb 23, 2005 | 08:37 PM
uncleb's Avatar
1 or 2 boxes?
I just got 2 12" subs, and want to throw them in a ported box. Looking at the specs, i can put EACH one in a 1.75 cubic ft box, meaning i can probably fit two in the trunk. Am i going to notice any difference if i put them both in seperate boxes as opposed to putting them both in one ported box.
Also, these subs run rms 750, but i'll be feeding each around 550....can i still go with the manufacturer specs on enclosure sizes, or am i going to have to go another route since i'm not too close to how much power the sub can handle?
Old Feb 23, 2005 | 08:38 PM
dark inspire's Avatar
El Presidente
which subs do you have?
Old Feb 23, 2005 | 08:45 PM
elduderino's Avatar
VP Electricity
The amount of power you are feeding the sub does not affect its T-S parameters... so don't change the box size.
You get max power handling by putting a woofer in a single enclosure. That said, it's easier to port a larger volume to a low frequency than a smaller volume of air... the port area and length are larger for smaller boxes.
Without knowing what speakers you have, I would still say that you sound like a good candidate for a 3.5 cu ft box with two 12" in it. Remember that port displacement does not count towards box volume (neither does woofer displacement).
I would take the porting freq recommended by the manufacturer and also get the driver displacement as recommended by the manufacturer, and then use somebody's enclosure calculator and figure the port you need for tuning at that note . I'd use a 4" port made from Home depot PVC.
Old Feb 23, 2005 | 09:34 PM
uncleb's Avatar
i got some treo ssi's
their recommended enclosure for ported is (per sub)
1.75 cu ft net F3=28hz
16 sq in vent, 16.5 in long
I don't know what 3 in F3 is, but it gives box size, tuning freq, and port size and length.
That's pretty much all i need to know to make a ported box, right? I was going to try n figure it out from there.
Old Feb 23, 2005 | 10:44 PM
elduderino's Avatar
VP Electricity
Hmmm. F3 is the frequency where the box is 3dB down... essentially how low the box plays.
Fb is the tuning freq of the box.
If you increase a volume, you change the size of the port required to tune it to a particular freq. I don't have SW on this PC but maybe you can get BassMech to figure you a box 7 cu ft tuned to 30 or so...
dirleton
Aug 6, 2024 08:19 PM
LoneRonin
Jan 4, 2016 01:03 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
