TSX: 04 tsx rear speakers
Old Jul 6, 2009 | 01:59 PM
gt489's Avatar
im lookin for a good set of rear speakers. i believe they are 6x9. i want to leave the stock amp but i want something with bass and thats a quality speaker. any ideas?
Old Jul 6, 2009 | 08:24 PM
feuss2's Avatar
10001110101
the sound quality issue with the rear speakers is a result of the low power of the stock amp, the 6x9's in free air, and the crossover/bass boost that is built into the stock amp. replacing the speakers alone will probably be disappointing, especially if you get something with a lower sensitivity then what you're removing...
you might consider:
remove the 6x9's
install a new amp - get the input signal from the rear doors, not the channels for the 6x9's
get a sub
Old Jul 6, 2009 | 08:28 PM
gt489's Avatar
need to keep the trunk space as is it not a bass problem that im having the 2 rear speakers are blown and just want something alittle better. not looking to spend crazy money i have another money pit called an s2000 that takes more then enough of that
Old Jul 6, 2009 | 08:43 PM
feuss2's Avatar
10001110101
http://www.parts-express.com/pe/psho...64&ctab=1#Tabs ???
Old Jul 7, 2009 | 09:03 AM
gt489's Avatar
are they any good ive never heard of the them? can they go right in with the stock amp?
Old Jul 7, 2009 | 09:12 AM
mattastick's Avatar
Those should be pretty interesting... Pull the 6x9's, and check their impedance (or it could be printed on the magnet like mine was). If the factory's are 4 ohm, the Tang Bangs should drop right in. If not, you may have problems.
Old Jul 7, 2009 | 08:37 PM
feuss2's Avatar
10001110101
all the speakers in the 1G tsx's are 4 ohm
Old Jul 7, 2009 | 10:32 PM
gt489's Avatar
are those speakers any good?
Old Jul 7, 2009 | 10:41 PM
mattastick's Avatar
They look to be a little inefficient, but they should help out with the low end in a pretty significant way...
Old Jul 8, 2009 | 05:46 AM
feuss2's Avatar
10001110101
choices are limited as far as 6x9 subs are concerned...
Old Jul 8, 2009 | 08:28 AM
PittIsIt's Avatar
for EVER more!
would be interested to try - what if you put 2 ohm speakers in? would the stock amp be able to handle that? i'm having issues with a 2 ohm door speaker i put in.
Old Jul 8, 2009 | 11:07 AM
mattastick's Avatar
The amp probably won't be able to play at 2 ohms. It's designed to run at 4 ohms, and that's why all of the speakers are 4 ohm resistances. Seems like you just wasted your money... Should've done your research first...
Old Jul 8, 2009 | 08:28 PM
feuss2's Avatar
10001110101
I saw a service manual for a pioneer HU that has the same output power amp IC (PAL006A) as the oem tsx amp. There is a 4 ohm min. There is also a protection circuit in the IC, which probably saved the amp.
Old Jul 8, 2009 | 08:35 PM
feuss2's Avatar
10001110101
Install these in its place:
http://www.datasheetcatalog.org/data...onics/6886.pdf
Old Jul 9, 2009 | 11:04 AM
PittIsIt's Avatar
for EVER more!
crutchfield is a batch of liars. i trusted them.
UGH
My Electrical engineer sister in law validated my suspicion that you can't run 2 ohm speakers on a 4 ohm setup. ugh.
Old Jul 9, 2009 | 11:36 AM
mattastick's Avatar
UGH
You shouldn't go off of 1 source of info... Whenever I'm researching a product, I always check what I read/hear in one place with someone else. This could be why it takes me so long to choose a product, but I've been very happy with my setups thus far.
Old Jul 9, 2009 | 05:28 PM
darowa's Avatar
Speakers aren't constant impedance devices. The impedance varies with the frequency of the input signal. Looking at the specifications for the Tang-Band speakers (4 ohms) shows a graph of impedances from 4 ohms to maybe 50 ohms. Usually the manufacturer will state the lowest impedance because that requires the highest current to drive and imposes the highest load on the amplifier.
A "2 ohm" speaker would require twice as much current as "4 ohm" speaker at some frequencies. That's quite a bit more current and as mentioned before the amplifier output circuit will probably limit the current output so it won't burn itself out.
The Tang-Band speaker is interesting for the 1G TSX application if it fits in the rear shelf speaker area without too much modification.
Old Jul 9, 2009 | 08:19 PM
feuss2's Avatar
10001110101
Originally Posted by darowa
..........The Tang-Band speaker is interesting for the 1G TSX application if it fits in the rear shelf speaker area without too much modification.
They are also on sale now for $49ea (down from $78.93)
Old Jul 10, 2009 | 10:03 AM
PittIsIt's Avatar
for EVER more!
aren;t you mr. perfect!
Old Jul 10, 2009 | 11:06 AM
mattastick's Avatar
Nope, you're just a dumb ass for not doing your research...
Old Jul 10, 2009 | 12:42 PM
PittIsIt's Avatar
for EVER more!
cool - i bet you feel awesome for berating others while you hide behind your keyboard. you should research not being an ass.
Old Jul 10, 2009 | 01:06 PM
mattastick's Avatar
Feel free to ask around, I've helped plenty of people on the forum... All it would've taken was a simple question on your part, and you would've found your answer... It only takes a couple minutes to start a thread and ask a question...
Old Jul 12, 2009 | 01:53 PM
feuss2's Avatar
10001110101
Going to try to Tang-Band's?
Old Dec 14, 2009 | 07:18 AM
Simba91102's Avatar
Old Guy
So has anybody tried these?
Old Dec 14, 2009 | 10:21 AM
mercman's Avatar
OP,
Since you are obviously not looking to blow the rear glass out of your car you can basically use any 4 ohm 6x9. An important consideration is the clearance for the deck lid torsion bars, a lot of 6x9s are too deep to fit in the TSX.
Trying to drive 2 ohm speakers from the factory amp will cause a reduction in performance and possible amp shutdown.
Jeff
Old Feb 19, 2014 | 06:56 PM
Jottle's Avatar
anyone ever tried the tang band's in the stock 6x9 spaces? Any impressions?
Old Mar 5, 2014 | 01:07 PM
Jottle's Avatar
bump
Feb 25, 2020 09:57 AM
Pegon95
Sep 15, 2015 01:54 PM
Joe Tschida
Sep 13, 2015 12:22 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
