TL: 02 tl type-s with 2012 black dvd v2.90 does not update
6th Gear
I recently purchased a navi update 2012 black dvd from www.acuranavi.com. i followed directions to install the new verision. upon installing it,I got a blank screen then followed by unformatted disk message. I installed the original disk back in and it work normal. I tried serval times and even resetted the battery to see if it worked,nothing. I returned the navi disk to navteq and received a new replacement. I tried installing it, nothing work. The screen was black. I also resetted the navi and still nothing. I put the original disk back in and it worked fine. Could the dvd rom unit it self could be bad? I also checked the wiring and everything is ok. Anybody have any ideas of why its not working? Any help would be appreciated.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
Hopefully you will get it solved soon coz this forum contains a lot of geniuses. What version is your previous dvd? I want to buy your old disk if you successfully updated to 2.90. PM me when you are successfully done.
I just picked up a 2001 CL Type-S with Navigation. I liked the Nav unit so I ordered the new 2012 update disk. I installed it today and ran into the same issues you mentioned. I tried various combinations of inserting, ejecting, power on and off. Eventually I got it to take and got it updated. I wish I could tell you the exact combination that works but I can say that after about an hour I was driving through my neighborhood on streets rather than a blank screen. Good luck.
You may need a disc that updates the bios before being able to run the newer discs. Usually it updates graphics etc. Call/email the navteq people and let the know if there's anything extra you need to do before going from your current version to the newest one you have.
Silvermoon_Knight
10-22-2015 06:25 PM
