02 CL w/NAV. Can I replace my head Unit?
Old 08-06-2002 | 04:39 PM
adairbt's Avatar
I would like to replace my factory head unit and install an amp and head unit I already own. How would I handle the output of the NAV through the Stereo? Currently I hear the NAV voice cut into my music as I listen to it. Do I have any Head Unit options ?
thanks !!!
Old 08-06-2002 | 06:34 PM
mattrush78's Avatar
The Quite One
There is not much more you can do, but have the nav mute your headunit and run the nav output back to one of your amp and use a y adaptor. The output of the nav is just a low level output signal. No aftermarket headunt can handle the output of the nav and play your music at the same time.
Matthew
Old 08-07-2002 | 05:29 AM
NJ_CLS_driver's Avatar
I agree. The headunit I have has a audio interupt, so when the signal comes across it does a 20db mute. Most guys put a speaker in the center near the headunit for the audio, or you can run it to a small amp on its own, but it might be loud if you have the gain turned up on the amps.
Matthew
Ol'Dave
09-05-2020 02:56 PM
02-25-2020 09:57 AM
Soul_Deamon
11-13-2018 04:44 PM
Skirmich
09-15-2015 06:41 PM
yahelou
09-06-2015 09:12 PM
Quick Reply: 02 CL w/NAV. Can I replace my head Unit?
