CL: 01 cls front door speaker issues
Old May 1, 2011 | 08:11 PM
camjones92's Avatar
7th Gear
every thing i have read says the factory speakers are 6 1/2" but i bought rockford frosgate 6 1/2"s but the holes to screw them in dont match and it dont fit in the door is it actually that size or should i take it to a shop and have them make the hole bigger and drill me some holes to screw them in? any ideas? if you have one just pitch it at me no matter how crazy even if it involves a purple elephant named paul i dont care i need ideas
Old May 2, 2011 | 05:58 AM
NobleTL's Avatar
Crutchfield gives speaker adapters with the 6.5s when purchased I know, but I'd like to know where to buy them outside of Crutchfield. Or an alternative as well
Old May 2, 2011 | 02:42 PM
Skirmich's Avatar
Wierd I tought it Uses the same Size of the Stock TL that is 5-1/4 Not 6-1/2.
Mehh there are some little differences after all.
I installed 6-1/2 either way but I had to Cut some extra plastic from the Stock Holder to make them Fit.
Old May 3, 2011 | 03:39 AM
camjones92's Avatar
7th Gear
hmm... i believe the only way to do this correctly is to cut the whole bigger then drill new screw holes and use speed nuts or simpler cut a mounting hole in the door panel it self and used the speed nuts to hold the fabric down after you spray some apoxy on there first and used the speed nut for some thing the treads on the bolt to hold on to for right now i have them in what spacer the dumbass at the sound shop said would work and zip ties don't get me wrong it still sounds good and its a strong hold but i want it to look a lot better
camjones92's Avatar
7th Gear
hole*
Old May 3, 2011 | 03:55 AM
Skirmich's Avatar
I Used Clean RTV Silicone to Seal the OEM Spacer + Hold the Speaker, I didnt use any Screws at All only the Stock ones that Hold the Spacer Itself.
Sounds Good and the Speaker itself is Secured like Stone to the Spacer havent had an Issue since.
Old May 3, 2011 | 08:06 AM
NobleTL's Avatar
I thought I could use the basket too but there would be no way to fasten the speaker in. I went to a stereo shop yesterday and they even said it would be easier to use the adapters and would give them to me free since I had my stereo installed. Mine are mb quartz and even with a lot of trimming there's no way I could hold the speaker in and use the basket
Old May 3, 2011 | 01:38 PM
Skirmich's Avatar
Use the RTV Silicone!! It will Hold The Speaker Plus seal the Gaps!! It Works!
Ill try to Take some Pics for you!
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
handsom-hustla
Nov 13, 2015 05:04 PM
08 NBP TL
Sep 8, 2015 08:49 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
