Navtool & Back up camera install pics with notes
This are the things i used for this project:
*Navtool-awesome seller i offered 190 and they accepted great deal!!
http://www.ebay.com/itm/04-08-Acura-TL-Navigation-Video-Converter-Add-DVD-NAV-TV-Rear-Back-Up-Camera-/280989009053?pt=Motors_Car_Truck_Parts_Accessories&hash=item416c40049d&vxp=mtr
*Water proof camera- works great!!
*18 gauge wire
*locking quick splice connectors
*electrical tape
*multimeter a MUST!
*common sense
*dremel-must cut the middle piece of the tag holder up top and this tool made it a lot easier and cleaner look.
* drill and bits
camera has:
*video (yellow cable) just run it down to the Navtool and connect to Video 2.
*Power ( red cable) has 2 small wires red for 12v which i spliced into the back up light wire (green wire) which i also used for the navtool reverse +12v and black for ground.
*i made my camera screw holes with a 1/8 bit and got some self-tapping screws worked great
* in order to make the wire fit thru license bulb assembly you will need to cut about 6 inches from the camera and then rejoin the connection.. its cake dont sweat it!!
*i added some velcro between the camera and car to give it a better angle before i tightened down the screws so my camera would not point down so much and i got it perfect i think!!
navtool has:
*red wire (accessory 12+v) this wire goes on the yellow and red wire on the 8 pin white connector behind the navi dvd player (located in the trunk right rear)
*Orange (reverse lights 12+v) goes on the + wire (green wire) of the back up lights harness
*gray (parking brake cable) black (ground) goes on splice on to one of the existing ground on the chassis ( cant miss it it has about 6 ground on it)
* yellow (push button or switch cable) you can run to the center console to switch from video 1 and video 2. (i did not use it but i left it prepped when i receive tvs and dvd player)
MAKE SURE YOU DISCONNECT BATTERY BEFORE SPLICING INTO ANYTHING!!! COMMON SENSE BUT JUST A REMINDER!!!
i was rushing thru it so i missed a lot of pics but i got the important ones or the ones i had doubts about so i hope it helps a lot of yall!! GL
Amazon.com: Waterproof Car Rear Vehicle Backup View Camera High-definition Cmos 170 Degree Viewing Angle E363: Electronics
*18 gauge wire
*electrical tape
*multimeter a MUST!
*common sense
* drill and bits
camera has:
navtool has:
Grey Gonzalez (03-25-2013)
thanks! it was pretty easy for the cam just time consuming and patience!!
how was your Isimple install?? i got to jump on that one soon so tips would be certainly generous sir!!
supadavesNHBP (03-25-2013)
Grey Gonzalez (03-27-2013)
RPF1+RS3 FTW
I just installed the same setup as you last weekend. Navtool and the exact same camera. For my camera I did the wire just to the side of the light and put a grommet in there so it seals perfectly with the light back in place.
Here is pic:
I had to do the same thing with the spacer to get the correct angle on the camera.
Nice job man, I love having a cam now.
Here is pic:
Awesome man it looks good!! To me is a must have specially if you have tinted windows. for me it was easier making the hole on the license plate light assembly I did add some rtv so it don't leak and it hasn't yet!! Thanks for sharing!!
9th Gear
Ok. So I just started prepping everything to install.. but maybe I drank way too much and smoked way too much. (I don't smoke or drink)... but for some reason... the wire colors you are taking about does NOT match up with mine.. I have no gray wire, the yellow wire on mines doesn't even have a label on there, I don't have a wire with a label for handbrake.,
so, I've emailed navtool... but no response. So if anyone could help, it would be greatly appreciated. Thanks everyone
Dan Martin
Cameras & Photography
18
08-02-2006 02:19 PM
