Glitchy Steering Wheel Controls
I have read some of the older threads about the issue when the volume up button changes the track or radio station channel and the volume down increases the volume depending on how you turn the steering wheel. We are also experiencing this. Is this something that is fairly common amongst you owners and is there a permanent fix available that some of you have tried? Thanks.
I have the same issue, tends to happen most when it's hot out. Sometimes banging my hand against the buttons a couple times works, if not pulling over and turning the car off and on again works every time. Still definitely annoying though.
