Adding spacers after alighnment....
Old 05-29-2015, 12:34 AM
kukio's Avatar
Will adding spacers after getting alighnment throw the alighnment off?
Old 05-29-2015, 07:31 PM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
No. Spacers will not change the alignment angles of the wheels/tires.
The same goes for when getting new wheels, new tires, rotating tires, or replacing brake pads and rotors.
Old 05-29-2015, 09:45 PM
kukio's Avatar
Thanks man. Im hoping .5"spacer will be enough to bring that rear tires out. I shouldve went with 8" wide.
Old 05-30-2015, 01:57 PM
usdmJON's Avatar
Make sure you buy spacers with pressed in studs if you go that wide.
If you are interested i do have 15mm spacers from garageline. They sell for about 100. Ill do 70 plus shipping. They were on my ilx but took them off when i got my 8in wide work wheels.
Old 06-01-2015, 07:20 AM
aomechmarine's Avatar
Dude you need at least 25mm spacers for the rear Id recommend the either garage line or the Hand R wheel spacers I have. You will be be flush in the back. If you get Jon's 15mm spacers for the front, that would also work. I have 25mm spacers all around on the stock 17x7 wheels, front is pretty flush to the fender, rear could push out a tad bit more, trust me on this. If you want the front to stick out more, then just get 25mm all around.
Old 06-01-2015, 03:18 PM
usdmJON's Avatar
My bad. I have 20mm for sale. Not 15mm.
Id go 20mm up front and 25mm rear. Thats what i was going to do before i got new wheels.
RLX-Sport Hybrid
3G RLX (2013+)
27
12-07-2018 12:11 PM
CL-S progression 01
01-26-2016 04:15 PM
Froid
09-27-2015 06:16 PM
Quick Reply: Adding spacers after alighnment....
