2001 Acura TL hid headlight failure
Old 08-10-2018, 05:22 PM
3rd Gear
Deus Ex_Machina's Avatar
Hi guys I have a 2001 acura tl and I have a serious issue with the headlights. Both of them flicker on and off repeatedly and its usually one or the other. On my way to work at 5:30 am both of them turned off which was a bit scary on the interstate. I have the factory hid lamps and I was told I need to replace both driver and passenger side assemblies. Is this true or is there a less expensive fix? Thanks in advance
Old 08-10-2018, 08:31 PM
USAF Veteran
Saudade's Avatar
Did whoever told you actually test them?
Do the high beams still work?
Old 08-10-2018, 11:48 PM
3rd Gear
No actual test just a visual inspection. High beams still good. I Just dont wanna blind nobody early in the morning and thank you for your reply
Old 08-11-2018, 01:28 AM
Received 8,585 Likes on 6,631 Posts
Don't get another OEM kit. They're poorly insulated and it will fail again.
https://www.theretrofitsource.com/ma...epair-kit.html
Old 08-11-2018, 08:17 AM
frankjnjr's Avatar
IMO: I have no problem with replacing either the ballast, or igniter, with OEM Used parts. If you have access to a pick-n-pull, you can buy a used ballast for around $15.00. I have replaced several for friends, with no complaints.
hondeducation
12-22-2017 02:37 AM
mr shickadance
03-09-2014 12:55 PM
Terayon
02-20-2012 01:06 PM
cyclonemike
01-14-2008 03:20 PM
Quick Reply: 2001 Acura TL hid headlight failure
