Decking J32A2 BLOCK
Old 07-13-2018, 10:11 PM
AcuraMikey's Avatar
Question Decking J32A2 BLOCK
Decking my block ..j32a2.. by how much should it be decked ??im also putting in j35 internals and high compression pistons all together it should be around 12:0:1 !!Thank you for your replies!!
Old 07-13-2018, 11:10 PM
Unregistered Member
Karanx7's Avatar
Why do you want to deck it? If you want 12.0:1 then you don't need to deck it. Check it for straightness (heads and block), and replace the head gasket. If it was running fine before, it will probably be within straightness spec.
AcuraMikey (07-14-2018)
Old 07-14-2018, 02:25 AM
AcuraMikey's Avatar
So a resurface would be fine?? I just want the gaskets to seal perfect without a problem ..Tbh i got the engine off ebay 100,000 miles supposebly ..thanks for your response!!
Old 07-14-2018, 08:19 PM
Unregistered Member
Karanx7's Avatar
You need to measure the head and block for straightness. Takes about $25 in tools. If you are within spec, then you don't need to take it to a machine shop. Just clean the head and block surfaces, and you'll be good.
AcuraMikey (07-15-2018)
Old 07-15-2018, 12:21 PM
AcuraMikey's Avatar
Thanks for the great advice !!!
ksu90
03-16-2021 06:55 PM
AcuraMikey
05-19-2018 10:08 PM
boxmanryan
06-02-2015 05:48 PM
DEPTLS
12-19-2010 05:55 PM
G
Home & Garden
26
06-23-2010 03:53 PM
Quick Reply: Decking J32A2 BLOCK
