Decking J32A2 BLOCK
Old Jul 13, 2018 | 10:11 PM
AcuraMikey's Avatar
Question Decking J32A2 BLOCK
Decking my block ..j32a2.. by how much should it be decked ??im also putting in j35 internals and high compression pistons all together it should be around 12:0:1 !!Thank you for your replies!!
Old Jul 13, 2018 | 11:10 PM
Karanx7's Avatar
Unregistered Member
Why do you want to deck it? If you want 12.0:1 then you don't need to deck it. Check it for straightness (heads and block), and replace the head gasket. If it was running fine before, it will probably be within straightness spec.
Old Jul 14, 2018 | 02:25 AM
AcuraMikey's Avatar
So a resurface would be fine?? I just want the gaskets to seal perfect without a problem ..Tbh i got the engine off ebay 100,000 miles supposebly ..thanks for your response!!
Old Jul 14, 2018 | 08:19 PM
Karanx7's Avatar
Unregistered Member
You need to measure the head and block for straightness. Takes about $25 in tools. If you are within spec, then you don't need to take it to a machine shop. Just clean the head and block surfaces, and you'll be good.
Old Jul 15, 2018 | 12:21 PM
AcuraMikey's Avatar
Thanks for the great advice !!!
ksu90
Mar 16, 2021 06:55 PM
AcuraMikey
May 19, 2018 10:08 PM
boxmanryan
Jun 2, 2015 05:48 PM
DEPTLS
Dec 19, 2010 05:55 PM
G
Home & Garden
26
Jun 23, 2010 03:53 PM
