My Zulu Delta X-ray
Old 07-21-2018, 05:47 PM
Graphite Ghost
robpp's Avatar
My Zulu Delta X-ray
The following 2 users liked this post by robpp:
Acura TL Builder (04-16-2021), justnspace (07-21-2018)
Old 07-21-2018, 06:29 PM
Received 16,260 Likes on 11,971 Posts
Welcome back
Old 07-23-2018, 02:01 PM
Graphite Ghost
robpp's Avatar
shhhhh
justnspace (07-23-2018)
Old 07-28-2018, 04:50 PM
Graphite Ghost
robpp's Avatar
some interior pictures. and window sticker
Old 07-31-2018, 02:32 PM
Graphite Ghost
robpp's Avatar
blendmount and mirror power tap
escort redline
Old 07-31-2018, 06:03 PM
Graphite Ghost
robpp's Avatar
LaminX Yellow
Old 08-05-2018, 04:31 PM
Graphite Ghost
robpp's Avatar
Must have
New oem
Overdue
Old 08-07-2018, 03:41 PM
Graphite Ghost
robpp's Avatar
Done.
Old 08-17-2018, 01:23 PM
Graphite Ghost
robpp's Avatar
Transmission 3 x 3
Fill Plug washer 24 mm. 17mm head.
Drain Plug washer 18mm head 3/8 square
Mine took about 3.5 each time.
Drain Plug Magnetic
Fill Plug
First one used NOS label
First drain
Second Drain
More Fluid New Label
Number 3
Transfer Case Drain and Fill
Fill Plug 18mm crush washer 3/8 square plug
Drain Plug 18mm crush washer 3/8 square plug
Fluid for Transfer Case
Old 08-17-2018, 01:34 PM
Graphite Ghost
robpp's Avatar
i got some Black WeatherTech just for the front.
xtcnrice (08-20-2018)
Old 08-20-2018, 12:36 PM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
nice early stage progress rob I recall how happy I was when I first put in my weathertech digital floor liners
Old 08-20-2018, 04:53 PM
Graphite Ghost
robpp's Avatar
Yeah I guess none if this is real Progress on a build but more like getting comfortable, maintenance up to date as I don't know all the history, etc.
But TBH not too much else going on over here.
ZDX is even more rare than a Wagon : thumbsup:
Today I changed the oil and put the OEM rear bumper applique on. Was a big day LOL
Bought the replacement door panel
Color is correct
rear bumper protector
Oil filter wrench and drain plug wrench
New 14 mm crush waher
Cargo area led
FilTech A01 OEM HONDAHOND FILTER
Mobil 1 5w-20
Proper wrench 65-67/14
Mileage is 68050.
Old 08-23-2018, 08:05 PM
Graphite Ghost
robpp's Avatar
new car inspection said needed new sway links to resolve slight jiggle noise
Rock Auto Moog Problem Solver
$52 for pair delivered.
Remove need 6mm Allen and 17mm wrench.
These aren't for everyone as they require grease service every once in a while.
install is 18mm socket and 19mm open end yo hold shaft .
Then some grease and I had some rubber caps that don't fit right but on until I get something better
Old 08-23-2018, 09:08 PM
zdxsr's Avatar
Yep. Mine wore out around 55K miles. Rattling heard in the front end when going down a bumpy road.
I think the rear ones are next, slight rattle in the rear when going over something like railroad tracks, just haven't had a chance to check them out.
Old 08-23-2018, 09:35 PM
Graphite Ghost
robpp's Avatar
Yeah I'm planning those too.
Next up for me is Coolant change. I'm debating to touch the hoses and thermostat too....or figure those can be done with 100k service.
Old 08-24-2018, 04:10 PM
Graphite Ghost
robpp's Avatar
No pictures but to keep my documentation up yo date....
Today did coolant drain. Both radiator and engine block. Block is 12mm and you need 1/4 ID hose to drain. Removing wheel makes it very easy .
Filled with Honda Type 2.
Old 08-29-2018, 06:49 PM
Graphite Ghost
robpp's Avatar
Driver door panel replacement.
NEW:
​​​​​​​OLD:
Old 09-07-2018, 04:17 PM
Graphite Ghost
robpp's Avatar
New rear sway links
Moog
​​​​​​I also drained and filled the differential.
About 2.75 qts of Honda DPSF.
20mm washer on fill plug
18mm on drain plug
Old 09-07-2018, 08:14 PM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Christ almighty,
firstly, you know your fuckin maintenance...gonna assume you're a tech or were in your past life.
Secondly, damn right for loving the ZDX. I had one as a loaner long ago and although it's not for everyone, it's a
futuristic spaceship that you rarely ever see...cargo space is no worse than my vagon so technically it's practical
as hell for what it is.
I'll definitely be following your progress!
Old 09-08-2018, 10:38 AM
zdxsr's Avatar
Christ almighty,
Judging by the condition of the 68 Chevelle and the large tool chest in the background, my guess a mechanical background or dedicated car guy like most on here. Irregardless, on the ZDX
Old 09-08-2018, 07:29 PM
Graphite Ghost
robpp's Avatar
Christ almighty,
I tease my buddy that has a 2017 Shelby GT350 is less rare than my ZDX.
Im a car guy that refuses to pay the stealer for anything I can do myself. An early purchase was a service manual set. Worth every penny.
And Im just a backyard mechanic at best. But I do enjoy the wrenching, had many hot rods, classics, Harleys, etc over time.
Lastly, Im OLD as dirt//
Its a 69 El Camino but close and Im just a car guy !
ZDXFTMFW
Old 09-08-2018, 08:39 PM
zdxsr's Avatar
Ah yes, I see the back end now. Had a 69 Camaro, great year for Chevy muscle!
Old 09-08-2018, 08:43 PM
Gotcha...
well, if I keep going from the age I am now, I should be a good enough backyard mechanic myself.
Love your automotive choices...nicely done.
Old 09-11-2018, 03:56 PM
Graphite Ghost
robpp's Avatar
Today I paid to have the brake fluid flushed. Wanted them to look at the noise in the front suspension
i replaced front and rear sway and some noises went away but not all
Said the found a loose front left lower control arm.
And same wheel, the metal clips that holds brake pads was missing. Pads were flopping around.
Noise gone.
And check off my last maintenance item:
Brake fluid DONE
Old 10-13-2018, 04:38 PM
Graphite Ghost
robpp's Avatar
I was never happy with the yellow laminx on the fogs when lights were off.
​​​​​​So I removed it and bought some 2700k LED H11 fog bulbs from Xenon Depot. Hard to get s good picture with my phone when on but you get the idea
off
Box
LC-TL2002 (10-14-2018)
Old 10-16-2018, 06:30 PM
Graphite Ghost
robpp's Avatar
More maintenance:
New Honda Wiper Blades. Had some crap arms.
And I bought an extra set of rubber blades for next time.
Next up some Clear .040 LaminX to protect the fogs. I removed the Yellow film, added Yellow LEDs prior.
And I haven't installed this yet....need to consult the manual, but this b pillar piece was damaged when purchased.
Old 11-15-2018, 03:29 PM
Graphite Ghost
robpp's Avatar
Quad exhaust mod
Wintwr mod
Blizzaks DM-V2 255/50R19
Old 04-23-2020, 02:16 PM
Graphite Ghost
robpp's Avatar
New wheels and tires
The following 3 users liked this post by robpp:
Emii101 (09-25-2020), justnspace (05-13-2020), ZDixie (06-26-2023)
Old 04-23-2020, 10:58 PM
DJ Iceman's Avatar
I like it! Nice job!
Old 05-13-2020, 04:51 PM
Graphite Ghost
robpp's Avatar
Front Brakes
New Front Brakes
Old 05-13-2020, 06:41 PM
wow, I really enjoy your ZDX!
Old 05-14-2020, 08:06 AM
Still going strong, nice to see you, man.
robpp (05-16-2020)
Old 08-05-2020, 12:08 PM
Graphite Ghost
robpp's Avatar
I chickened out and had the timing belt etc done by a local shop I trust.
76,500 miles but in service 8 years. And came from Vegas to here. very dry climate.
I might have gone a bit longer but I may do a road trip in October so its done.
justnspace (08-05-2020)
Old 08-05-2020, 12:12 PM
being proactive never hurt anyone!!!
Good to see you, Robpp!
The following 3 users liked this post by justnspace:
dynodan (05-30-2021), robpp (08-07-2020), ZDixie (06-26-2023)
Old 02-08-2022, 06:27 AM
Graphite Ghost
robpp's Avatar
88,000 miles last week. At 87 I did a trans drain and fill one time and transfer case fluid. Cabin filter.
One note: I LOVE the Stoptech brakes I installed the spring of 2020. Great stopping. Nary a bit of dust after weeks of driving.
Got some creaking when I back out onto the street, I am thinking front strut mounts, front struts, sway bar bush. Rear struts.
With standard suspension, what are the choices for new struts? Looks like OEM is no more?
Old 02-21-2023, 12:38 PM
Graphite Ghost
robpp's Avatar
100,000 plus
Hi Nothing much new except I moved. And I used zdx to help me haul stuff. Then the Turkey Rod Run in November. So I did a 3x3 on my trans today.
DW-1 FTW lol
Old 05-18-2023, 01:38 PM
Graphite Ghost
robpp's Avatar
102125 051823
102125 miles calls for some new spark plugs.
NGK ILZKR7B-11S X 6
Old 05-18-2023, 04:35 PM
I saw a ZDX on the road the other day...very cool because you NEVER see them around.
You own a classic, Acura was visionary.
Old 05-18-2023, 08:02 PM
Graphite Ghost
robpp's Avatar
I'm in Florida since 2020 and I have yet to see another one. I hope they don't reuse the ZDX name on the new electric thing.
Old 05-19-2023, 07:22 AM
It would make sense for them to.
I used to see them around, had one for a loaner.
I did not like that it was tiny for an SUV...hitting my head on the
way in and our LOL...but if you can get past that, it was a cool
futuristic looking thing.
Quick Reply: My Zulu Delta X-ray
