f#^ked myself good
Old 09-13-2018, 09:02 PM
phil-e phil's Avatar
f#^ked myself good
greetings, new to owning a TL
co-workers 06 started giving him transmission problems,
600$ later i drive it 10 miles or so to my garage.
not knowing any better, i buy a very low mile 07 from the auction.
now i owe two TL's. Both silver with black interior.
both cars have empty engine bays at the moment
lucky me, the subframe from 07 is damaged after discovering the transmission is different.
so i need to locate a subframe for an 07 TL. or sell the engine and trans from the auction car to fund the purchase of a 06 rebuild.
wish me luck gang
cheers
ill share some photos with you all soon
Old 09-14-2018, 06:23 AM
teh CL's Avatar
Shouldn't be hard at all to find a subframe for the 07'
Old 09-14-2018, 06:35 AM
Received 16,260 Likes on 11,971 Posts
sounds like you know what you're doing. Good luck
Old 09-14-2018, 07:19 AM
no it isnt. but i did get a quote for 750,
thats more then what i bought the 06 for.
thanks but i shouldve done some reading before i started turning wrenches and opening wallets
Old 09-14-2018, 07:28 AM
teh CL's Avatar
Yea a lot of ppl that aren't familiar with these car think 04-08 are all the same, which of course they're not.
Not sure where your located but there's plenty on car-part.com in the $200 range. I'm assuming it's an auto.
Old 09-14-2018, 09:59 AM
Located in philly, also named Phil... I found three different part numbers for subframe sad well as different control arm part numbers for an 2007. Don’t know if I can use my 06 arms on an 07 subframe
Old 09-14-2018, 10:54 AM
teh CL's Avatar
Looks like the 07' subframe is discontinued so the 08 is the only one available, new anyways. Same setup regardless. The 3rd part number you found is more than likely the 6MT subframe.
08' Acura TL Base/Type S Auto subframe.
Also, there's no reason the lower arms wouldn't be compatible, it's the same car/suspension setup. The only difference is the transmission lower mounting points.
Old 09-14-2018, 11:39 AM
yea that bracket for lower trans is what got me.... if i were to use the engine and trans from the 07... i just need a subframe and ecu at that point right?
Old 09-14-2018, 12:37 PM
teh CL's Avatar
The wiring for the ECU is different as well
niju321
Health & Fitness
56
10-17-2008 03:00 PM
SupraS4
04-12-2007 03:37 AM
Type X
05-11-2005 12:06 PM
LvMyCL23
10-09-2003 05:14 AM
amir was here
10-09-2001 11:56 PM
Quick Reply: f#^ked myself good
