Battery replacement
Old 05-31-2018, 11:13 AM
LTBM's Avatar
Post Battery replacement
2015 TLX, V6 fully loaded (no AWD) approx. 26,500 miles (second car) and it's all swell.
I would like to change my battery before it goes to it's resting place. At this moment its all fine.
Would like to know how I can change the battery (not by the dealer, Acura or Honda) and just do it myself without the potential of loosing all memory settings, etc.
Any suggestions on brand/capacity requirements?
Thanks for any suggestions,
David
Old 05-31-2018, 11:46 AM
Received 16,260 Likes on 11,971 Posts
buy 12volt motorcycle battery to keep your memory settings intact, while changing out real battery.
you can use any big name brands, as there are only a few battery manufactures, anyway.
frankjnjr (06-01-2018)
Old 05-31-2018, 04:34 PM
DohcIVTEC's Avatar
I generally go to Costco and get their batteries. Can't beat the price/warranty. The CCA is pretty good too.
https://www.costco.com/automotive-batteries.html
However, I used it when I had my old accord. I'm not sure if they stock the battery size for the TLX there. Also, this was before they switched to the Interstate branded batteries. They lessened the battery warranty on the Interstates.
Old 02-09-2019, 09:34 AM
Gene
genejohn1's Avatar
none for 4 cyl
Yeah, I just found out that costco/Interstate does not list a battery for a 2015 TLX 4 cyl, only for the 6 cyl.
Old 02-12-2019, 07:52 PM
Summer is Coming
Rocket_man's Avatar
I just use AutoZone. They make a version of a battery especially for hot climates like this. Haven't had an issue with it. I think the plates are slightly thicker and that seems to make the batter a little more reliable. Maybe a few less CCA but the car starts fine. I had issues with two earlier batteries. I have a small battery conditioner/charger and I connect it every now and then and top up the battery.
Old 02-13-2019, 05:18 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Make sure you guys are getting AGM batteries! These are required for newer cars with stop/start and will last much longer than traditional lead acid batteries.
Doc Holliday
18
09-27-2005 03:12 PM
shaolin
07-20-2003 11:28 PM
mcdanjw
03-11-2003 01:06 PM
Quick Reply: Battery replacement
