14 RDX AC blowing warm after recharge
Old 07-08-2018, 07:16 PM
4th Gear
khwilm's Avatar
My daughters 14 RDX started blowing warm air out of the drivers side vents with the AC about ten days ago. The passenger side was fine and blew cold air. It would intermittently work on the drivers side but quit this weekend on a six hour trip home. After reading through several forums I decided to check the drivers side control valve module. It functioned normally when I cycled from max ac to heat. Several in the forum recommended adding refrigerant. My ac pressure gauge indicated it was low so yestrday I added one small can. It was now blowing cold out of both sides but still reading around 35psi on the gauge. Fearing there might be a small leak, I added another small can of the leak sealing 134. When adding that can, the pressure never got to 50psi but now blew cold air out on both sides. My daughter just called me about three hours into her six hour trip back home and told me it is now blowing warm air out of both sides.
Any guesses at where to start?
Any recommendations for reputable shops in Wash DC area?
Thanks - Kevin
(my first post was in wrong location)
Old 07-09-2018, 11:51 AM
markAZ's Avatar
What kind of gauges were you using? One of those cheapies that reads only the low side or a set of real A/C gauges that read both sides? Unless you can see both high & low you can't tell what's going on. A/C systems are not something to fool with unless you know what you're doing. You can do a lot of expensive harm by just adding refrigerant without knowing what the problem is.
Old 07-09-2018, 12:51 PM
4th Gear
khwilm's Avatar
Admittedly, I did use a $20 charge hose with low pressure gauge. https://www.homedepot.com/p/AC-Pro-2...BM-4/204834456
More feedback from symptoms after charging with two cans: The AC was cold on the passenger side for about one hour, the both sides went to ambient. The AC would then kick in for 30 seconds and then back off again. Could I have over charged the system? It was not working today. Currently looking for a repair shpo in Northern Va / DC area.
Old 07-09-2018, 05:54 PM
Brown13's Avatar
Cycling on and off usaully means low refrigerant.
Old 07-19-2018, 10:09 AM
hongthan's Avatar
I recently did the recharge in My 06 Sienna XLE. The same thing happened (warm air came out from the vent). I then went to my mechanic friend to vacuum the system and recharge the a/c. He told me that air might get in. I had bad experience with this kind of recharge kit before and will not do it again in the future.
Thanks - Kevin
meirt
1G TSX Problems & Fixes
15
07-10-2014 09:13 PM
hazzardjk
05-27-2011 02:42 PM
smoger
05-05-2010 11:46 PM
Kingmeow
12-11-2009 11:29 AM
mrsteve
06-06-2005 10:23 AM
Quick Reply: 14 RDX AC blowing warm after recharge
