Thoughts on ST Suspensions 19mm sway bar
Old 06-05-2017, 09:00 AM
t3hhcaptain's Avatar
Since there are virtually no posts on the st suspensions sway bar... here goes:
I installed the ST Suspensions 19mm sway bar yesterday. I immediately went out to test the product and from what I can tell it is a nice moderate upgrade. I imagine the larger adjustable progress bar is a bigger upgrade. The reason I didn't want to go with it is because I wasn't looking for anything adjustable and did not want to do a mod that was irreversible.
The most noticeable improvement with the 19mm bar is the car feels better planted when coming in hot to a turn.
Installation was a breeze... I ordered the bar from Heeltoe and it came with the bar, Teflon taped bushings, brackets, four nuts and four washers. The instructions from ST Suspensions state to reuse the original mounting brackets so at first I was confused why it came with new brackets, but after trying the factory brackets on they were a bit loose around the bushing so I used the included ones. The most challenging part of installing it was soaking the endlinks with enough PBlaster to get the nut off without having to drill them out. I also took the rear of the exhaust off the hangers to make getting the sway bar out easier.
Overall if you're looking for a "sport package" or oem+ kind of upgrade and don't want to enlarge the mounting holes, I'll give a thumbs up to the st suspensions bar.
The following 2 users liked this post by t3hhcaptain:
julius071 (06-05-2017), xtcnrice (06-05-2017)
Old 06-05-2017, 05:02 PM
BROlando's Avatar
Received 1,166 Likes on 877 Posts
Cool. How big is the stock bar? I'm assuming both bars are solid in terms of actual construction? Or is one hollow?
Old 06-05-2017, 05:19 PM
I believe the stock bar is 17mm. I'm not sure if one is hollow or not, but the suspension techniques bar is solid cold formed powder coated steel.
justnspace (06-22-2017)
Old 06-22-2017, 02:13 PM
Former Sponsor
MrHeeltoe's Avatar
Nice review! You might consider reviewing the item on the Heeltoe site as well.
t3hhcaptain (06-23-2017)
Old 06-22-2017, 02:21 PM
Received 16,260 Likes on 11,971 Posts
Solid 17mm on the 2nd gen TSX
Originally Posted by Hondanews.com
Rear suspension
The multi-link rear suspension includes stamped-steel upper A-arms, cast aluminum knuckles, double lower tubular lateral links, tubular steel toe-control links, coil-over dampers and a larger (17 mm solid versus the previous 15 mm solid) stabilizer bar. This system provides outstanding agility and handling, together with a flatter ride and excellent control of noise, vibration and harshness (NVH).
Old 06-27-2017, 09:39 AM
Torn bushing
So the passenger side bushing has torn already. The driver side bushing has no obvious signs of tearing. I've got an open ticket with Heeltoe auto about a warranty claim. They requested pictures and I submitted them yesterday.
We will see how the warranty process goes and if the new bushing tears as well.
Old 06-28-2017, 04:58 PM
Sheefo2k's Avatar
Another item on my to do list. Please, keep us posted on the torn bushing problem.
Old 07-06-2017, 11:46 AM
Suspension techniques is sending me a replacement bushing. Will update when it is in and if it tears again.
justnspace (07-06-2017)
Old 07-06-2017, 11:56 AM
good thing it isnt a bracket to the subframe tear.
rubber bushings will fail over time, anyway.
Old 07-06-2017, 12:12 PM
This failed a little early at less than a month, but definitely good it isn't bracket to subframe lol.
Old 07-06-2017, 12:20 PM
Good guy, Suspension Techniques sending you replacement!
Old 07-07-2017, 11:25 AM
BROlando's Avatar
Someone else had problems with ST swaybar bushings.
I'd probably want an OEM bushing for a 19mm bar. But...which Honda had a 19mm bar...
Old 07-07-2017, 12:28 PM
I remember reading another thread about the bushings, too.
OEM bushings would be great but, yeah, I don't know if anything had them. It definitely wasn't the S2000.
Old 07-07-2017, 07:42 PM
BROlando's Avatar
Heck no. S2000 swaybars are SIZEABLE, bruv.
Old 07-14-2017, 06:46 PM
notalk's Avatar
That was me. https://acurazine.com/forums/second-...advice-957902/
ST sent me the new brackets/hardware (thanks to this thread or I'd never have known) and the clunk is gone. Interesting in that the original bushing which fell apart was all rubber, but the other original bushing was the new teflon-lined bushing. They sent me one old and one new with my bar. Then, they sent two new as replacements, but not the new hardware. (My clunk was the new bushing in the old bracket; not quite a perfect fit.)
Anyway, I think the CL's had 19mm rear bars and possibly another earlier Acura. I searched going back through when I thought the solution was an OEM rubber 19mm bushing. Hoping the teflon-lined bushings hold up. If mine fail, I'll probably go to a poly just for strength/longevity if no other reason.
Old 07-17-2017, 04:13 PM
Sheefo2k's Avatar
Glad to see this taken care.
Can any vendor confirm if new ST swaybar come with the correct hardware? Bushings and corresponding brackets?
Old 07-17-2017, 06:42 PM
When I ordered from Heeltoe it came with the correct hardware.
Old 07-19-2017, 11:25 AM
Sheefo2k's Avatar
I am now confused, if yours came with the correct hardware, how come the bushings failed?
Old 07-19-2017, 11:37 AM
rubber can fail; more of a QC (quality control) problem.
however, ST took care of it's customer and sent a new, presumably, better quailty rubber bushing
t3hhcaptain (07-19-2017)
Old 07-19-2017, 11:40 AM
Defective part? ¯\_(ツ)_/¯
What justnspace said.
justnspace (07-19-2017)
Old 07-19-2017, 11:46 AM
it's not likely they make the rubber bushings themselves and would have to outsource a rubber bushing manufacture. with rubber, there are many different compounds and mixtures to create what you see as a bushing. like concrete, if the mixture isnt right, you will get a bad product
but it was simple to revise. as seen by the fast communication between customer and ST
Old 07-19-2017, 11:55 AM
Sheefo2k's Avatar
I am back on track. You regained my faith in Suspension Technique ST. I am planning on buying the sway bar and the coilovers over winter for an early summer install.
Old 08-03-2017, 12:11 AM
Itr0059's Avatar
I install a oem Acura tl awd 20mm rsb on mine
Itr0059's Avatar
Hard to beat the price tag !
Old 08-03-2017, 06:05 AM
i wonder if the 25.4mm TLX RSB would bolt up
Old 08-03-2017, 12:52 PM
Itr0059's Avatar
Maybe but it would be off balance
without doing front also and a possibility to shred the mounting point anything over 20/22mm
Ur talking about a family sedan after all ;Cu2 are not a sports cars!
Old 08-03-2017, 01:00 PM
i agree with it being off balanced, with it being more rear biased...lift off oversteer!! YAY!!
but i disagree with your 2nd statement...the TLX is not a sports car either...and it came stock with 25.4mm bars!
i'm also rocking 24mm progressive bar on my TL.
and I did not rip subframe mounting points either.
and the CU2 is based loosely off the TL
Old 08-17-2017, 01:45 AM
Itr0059's Avatar
TLX and TL are engineer with bigger swaybar to begin with; not the Cu2 . Best exemple is the old TypeR vs regular Integra ; guys were ripping subframe left and right ! Personnaly i wouldn't risk it ! But i see your point also ....😁
Old 08-19-2017, 03:31 PM
Jaheri_cbp's Avatar
I have had the progress 22mm bar on my car for more than 3 years, tracked it, hooned the living piss out of it, put about 100k miles on it, and bushings and subframe are still ok, finally just ordered new progress bushings and moog greasables and really just as a preventative cuz miles and slightly loose feel, still no squeaks and rattles from the rear though.
xtcnrice (08-19-2017)
