ATF/Transmission cooler : to bypass or not bypass OEM rad
#41
The thing you're missing here is just because the engine is warmed up, that in no way means the radiator has achieved it's peak run-time average core temperature. Said another way, after only 20-30 minutes, the radiator is still well below the coolant temperature in the engine.
You can argue all you want, the Gen 3 TL never experiences a warmer radiator core than ATF temperatures under normal operating conditions.
04-06 TL its called a warmer with the 07-08 trans it's moved to the lower end tank of the radiator Honda calls it a cooler because it does allow for better temperature regulation compared to the old 04-06 trans (which is known for it's issues) .
Some older threads:
Check Post #14,
https://acurazine.com/forums/third-g...s-pics-754752/
https://acurazine.com/forums/third-g...warmer-826854/
#44
I have no temp data, only customer success stories by getting rid of the warmer and adding a cooler to non type-s models. Some type-s customers even prefer to upgrade to a B&M cooler for good measure.
JRock
07-06-2002 03:41 PM
EricL
2G CL Transmission Recall Q & A
07-06-2002 08:37 AM
