ROTORA Big Brake Kits: CL, TL, TSX
#163
Any explanation on why the 99-03 Acura TL (UA5 chassis) or the 01-03 Acura CL (YA4 chassis) rear kits wouldn't work on the 98-02 Honda Accords? I know my front BBK (RBK003.01) is interchangeable with those vehicles, so I'm still confused why the rear setups (RBK101.01/02, RBK140.01/02) wouldn't work. Has someone tested those out before on our Accords?
#164
#171
Registered TL Lover
i was not planing on just geting calipers but thinking of maybe mixing and matching there is a large gap between need and want for me.
I need new brakes in the near future
I want low dus/rust/noise
I dont need more stopping power buts its always nice to have
I want them to look pretty
and dont want to have to spend a arm and a leg in the process.
#172
Registered TL Lover
would the calipers fit with rotors of these dimencions?
Fronts:
Outer Diameter 300mm
Height 47.2 mm
Norm Thickness 28mm
Hub Reg 64.1mm
Bolt Size 12.6mm
Bolt Circle 5x114.3
Rear:
Outer Diameter 282.5mm
Height 58.6 mm
Norm Thickness 9mm
Hub Reg 64mm
Bolt Size 12.6mm
Bolt Circle 5x114.3
#173
Yes.
http://store.excelerateperformance.c...a/i-92973.aspx
I would recommend ROTORA Slotted rotors and ROTORA H2 ceramic brake pads for you. Also look into stainless steel brake lines and upgrade brake fluid (MOTUL DOT 5.1).
#174
All pricing is now on the web store a http://store.excelerateperformance.com Use promo code AZ ROTORA !!!
#177
All PM's have been answered. To order use our webstore at http://store.excelerateperformance.com or call us at 203-483-6100. Email us with any questions at sales@excelerateperformance.com
#179
#186
OTS mobile audio
I have a 2004 acura tl. auto. rotora bbk front and rear. Rear is 2 piston. front is 4 piston. i need rear brake pads. fc2, and i think it is rp.02.1.155 or something like that. Looking for a universal pad that'll fit. i really don't want to buy a rotora bad unless i have too. any help would be greatly appreciated
cycdaniel
12-17-2019 10:58 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
nuldabz
09-03-2015 05:49 PM
