I need to lower my TLX Aspec about an inch...
Received 6,470 Likes
Has anyone made springs for this yet? I was going to go with BC Racing coilovers, but I talked to Coilover Depot yesterday-they said you lose your driver modes with coils. So I'm back to considering springs instead.
Hondamobilemechanic (09-22-2021)
Depend on your budget. I wanted to get springs but it’s due to the pandemic so that is why everything are on delay. Only reason I jump in on BC because I have my wheels and tires in my friend shop waiting to install, hence need it for SEMA. So the wait time on BC is 6-8 weeks. Once either Eibach or H&R is out, I will sell the BC and get springs. But yes if you on a budget I’ll get springs. Or if I were you keep calling Eibach or H&R. The more inquiries they gets the faster they will speed up production
Steven Bell (08-20-2021)
Steven Bell (09-04-2021)
Anyone seen any sports springs/lowering springs yet?
Family Hauler
If you have an A-Spec, you don't have adaptive dampers (same as with the RDX). The drive modes won't change anything in the suspension.
Nexx (09-23-2021)
^^^ Yea, but there is no need to spend $1,035 when I don't care about adjustability of the shocks. I just want an inch lower.....
3 options:
1) cut your springs
2) do it right and get coilovers and sit the car perfectly while also being able to adjust the ride firmness
3) leave it alone.
$1000 isn't a lot for a quality drop.
And if 1000 seems like a lot then you don't care that much about doing it in which case leave it alone.
and if you're hellbent on the 1 inch drop and can't stomach the cost then cut a half coil off the springs and be done with it.
1) cut your springs
3) leave it alone.
Cutting the springs just for the looks is arguably worse than what the herrafrush/stance crew does to their cars. At least in their case, there's no "right" way to do it without sacrificing ride quality and handling. Wheras to achieve a one inch drop, there is most definitely a right way to do it that doesn't make the car drive worse.
Steven Bell (10-12-2021)
i thought only the type s had the active dampers ...& the a-spec did not?
I think all that will do is trick the computer into not putting into safe mode killing the ability to change drive modes...
I don't think it will actually retain the characteristics of active dampening and the changes that occur from actually switching modes.
BukvaMan
23
04-08-2009 02:24 PM
taewlee
07-14-2004 12:03 PM
