Wireless Charger
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Just got a new IPhone 12/128GB; the wireless charger is reading Green & Amber; subsequently, NOT charging
Phone has no case, as of yet; have tried turning the charger pad, on & off, several times; as well as restarting the car; no luck
Manual, says charger may be defective; I know it's not the IPhone; tried repositioning the phone; nothing
Any ideas, before going to the idiots at my dealer?
This is a known issue with the iPhone 12 and newer with Mag charging (as far back as Jan but perhaps even older from RDX owners). So far, Acura has no fix.
https://acurazine.com/forums/2g-tlx-...e-12-a-992167/
You may want to check the other threads for follow-up.
Sarah_Kelly (03-13-2023)
Believe it or not, Acura In-House Tech's, & Apple, confirm there's a problem; aka, NO FIX YET!
I turned the pad OFF, because it was DISCHARGING my IPhone
Both the Green & Amber lights blink, when you try to charge
The Acura Manual, says it's a defective charger; DUH!
Technology is beautiful, when it works!
What's the Latest on iPhone 12 Wireless Charging?
- What's the Latest on iPhone 12 Wireless Charging?
- There is a June 2021 Technical Service Bulletin that says Acura "is working on the issue."
- Is the iPhone 11 working OK with the Acura wireless charging pad?
- Any thoughts (WAG) on iPhone 13 compatibility coming next month?
Wireless Charging w iPhone 12 Update
I tested the wireless feature on the Type-S this morning using a borrowed iPhone 12.
1. I positioned it four different ways.
2. I removed the case.
The iPhone 12 would not wireless charge. BTW: A prior generation charged with no problem.
I have a Type S and my Iphone 12 pro max wireless charging connects about 50% of the time I set it on the charging pad. I don't have a case on it.
Update: yesterday saw the Acura tech at my dealer; STILL NO FIX!
FYI, just picked up our 2023 Type-S today and tested my iPhone 12 Pro, son’s iPhone 13 Pro Max, and wife’s iPhone 14 Pro Max on the wireless charger. All 3 began charging! Didn’t seem to be an issue.
But I’m still going to end up using wired connection most of the time for the CarPlay functionality.
MarcoTLX (02-19-2023)
