Wind noise from Driver's window
Hello fellow 2g TLX owners. Wondering if any of you have experienced noticeable wind noise from the driver's side window.
I can clearly hear wind noise when going above 50mph on corner of the window seal near the b pillar. If i press on the seal it quiets down. Have a service appt with the dealer, but wanted to get fellow owner's experience.
P.S. My puddle lights also stopped working the 2nd day of ownership.
Thanks,
Luis
Thanks,
Luis
Same here, haven’t experienced any or excessive wind noise when going down the road. As a precaution, you check the weather seals that go around the body frame and create a seal between the vehicle and the door - that stuff usually comes right off if you pull on it; make sure it’s seated correctly.
I know it's a completely different vehicle, but I'm sure they use the same crappy parts on different cars. My window seal on my 3G RDX was pinched between the door frame and the window. I noticed it once while fueling it up one day. They replaced it (poorly) under warranty. That being said, wind isolation isn't one of the car's strong suits and its gotten surprisingly worse in just about 2yrs.
Thanks,
Luis
Thanks,
Luis
I have had mine since the end of Dec 2020, no wind noise at all. Puddle lights went out pretty quickly.
Going in for my first service next week, A1. I will bring the puddle lights up for repair, not sure how long they will last.
